GT30R/EWG/Grimmspeed 3-port - question about boost control
Hey. I've bought GT30R for my car and wish to control boost via stock ECU. On my stock turbo it was really good thing and I don't want to loose this option.
Will it works? How should I connect vacuum lines to external wastegate? Or maybe the simplest way will be MBC ? |
which solenoid are you currently using?
Stock
Originally Posted by TJung
(Post 8705567)
Stock
not gonna work. |
So I should use some 3-port, yes?
Upgrade to a 3-port boost control solenoid (GM 3-port is the most widely recommended) and you are back in business.
Yeah, thank You sir ;)
Hello. I've searched a little bit more about differents between stock and 3-port's and didn't find the anwser. Why stock bcs will not controll EWG and 3-port will do?. Can somebody tell me how to install vacuu lines to 3-port and why one of ports must be vented ?
I am using a Grimmspeed BCS and it is great. I was having creep issues with my stock bcs spiking. Here is the link to Maperformance that has the install instructions http://www.maperformance.com/grimmsp...-ebcs-evo.html
This is a plug and play option that is the same OHM specs as the stock solenoid. |
Iam also using grimspeed boost silenoid. It works great and looks stock. It also comes with 3 ports which can be used with the external wastegate.
Thats great. I will buy it, but please explain me guys, why stock BCS can't do the same ? What is the reason ?
Stock 2 port will work just fine, just have to set it up the hose a bit differently.
However, 3 port is superior in fine tuning and response - Bryan |
From what I have read and experienced myself. The stock 2 port cant go much further than the stock boost pressure, but im guessing that was just because it was the stock WGA. And like GST said the 3 port is much more responsive and much better for fine tuning.
Originally Posted by GST Motorsports
(Post 8793566)
Hey again. I've tested today my Grimmspeed BCS with GT30R and Tial External Wastegate with 1 bar spring.
I was set my baseline boost, BEC and baseline WGDC to zero, because I wanted try will it works. Boost is spoolin really smooth and not agressive, holds 1 bar (that WG spring says) until about 6000 rpm, and then is gettin up to about 1.2 bar. What am I doing wrong? Or maybe it is normally? |
