first start problem
car won't start on first and second try when the engine is cold. only at third try it bogs like impreza for a second and then starts ok. It's an e3 with 96530706, injector size and latency scaled for 510's. all other injector/kranking tables are untouched
what tables should I change and how, to sort this cold start problem |
You're probably getting too much or not enough fuel. Try adjusting the MAF scaling between 19-50 and see if you get anywhere.
adjusted the MAF. before my afr was ~12.0 at Idle, now it reads 14.7 but kranking problem still remains
anybody ?
bump
Originally Posted by stunt2
(Post 9270943)
which tables axactly and how ?
bump
