JDM map sensor with 94170715
Yes as it states im far away from my car at the moment to see if it will work correctly in my evo 8 but, i figured i would ask first
is there a setting i can change or what values would i need to put in to run my evo ix Map sensor to work with the 94170715 V7 rom? i have read alot of post but i could not find anything about it i also asked on the V7 post still didnt get a response. |
I have an EVO 8 with JDM map with 94170715 V7
So then I won't have to change any settings that's cool then I can't wait to try n switch over to it then
sorry to revive a very old thread but can anyone confirm that I don't have to change anything in ecu to run JDM MAP sensor if i'm on v7 94170715??? been searching everywhere but can't seem to find the right answer. i just changed over alot of the data based offf whats one user posted in the fourms using but 94170715 but then i read this post. please help !!!
The only thing you need to check is that the rom has the correct JDM map sensor scaling, upload your rom here if possible.
