Connect to ECU Help
Same issue allot of people have had;
sending init sequence 1 (0001) sending init sequence 1 (0003) sending init sequence 1 (FFFF) sending init sequence 1 (F0F0) no response to any known code interface close But none of the fixes I find work Battery voltage is fine, ecu unlocker is on (assuming its working) and nothing. Car doesn't even start |
Apparently with a 2.0 you need to connect the reflash connector even to get it to read.
