-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   disabling EGR 2006 EVO 9 EDM 88580714 (https://www.evolutionm.net/forums/ecu-flash/572555-disabling-egr-2006-evo-9-edm-88580714-a.html)
dimacoupe Sep 1, 2011 05:31 AM
In the ECU:
-XXX- See Mr Fred Quote Below, might be good anyway- Change Periphery 0 (FAA) bit 11 to 1 (to disable EGR Timing advance)
-XXX- Not necessary if disabled correctly - Change Periphery 2 (FCA) bit 09 to 0 (to disable P0401 EGR Test)
-XXX- Unrelated, but a good change for anyone with problems - Change periphery 4 (FEA) bit 14 to 1 (to disable MAP vs Baro test on startup - not necessary but doesn't hurt)
sorry for stupid question. this is right for 2006 EVO 9 EDM 88580714 ?
EVAP and FPS was not removed, only the EGR.
thanks
