EvoX ACD reprogramming
Does anyone know any threads that talk about EvoX ACD reprogramming or xmls for it?I'm pretty sure mmcflash can do it, but I want to find out for sure... does ecuflash do EvoX ACD reprogramming at all?
UPDATE: http://www.evoscan.com/technical-veh...d-abs-sawc-ecu Does anyone have any photos of inside an EvoX ACD? Does it look the same as this Outlander one below? Is it 512K rom size too? https://www.evolutionm.net/forums/9722431-post35.html MMCFlash Module 3 Read/Write ACD Outlander XL 31036 1XG4E 8631A083 G1T32977 H 8130 SW VJF029 CPU MH8104F Download 8631A083.bin (512K) http://www.evoscan.com/images/stories/ACD_MH8104F.jpg |
Try to pm Vgergo : https://www.evolutionm.net/forums/me...14-vgergo.html
I know the guy from hungary, he does tunes rally cars and serious race cars, there for if there is a solution and program for it he has it. Rob |
yes EcuFlash does it.
no there aren't any xml's for it yet |
We posted some pictures and chip information in the other ACD tuning thread from my car.
https://www.evolutionm.net/forums/8284214-post286.html (and some other posts also) As far as I know there hasn't been any development on it. |
Originally Posted by tephra
(Post 9731004)
you need to bench it...
Sabin doesn't want the details revealed at the moment :) |
Are you able to read the code that runs the display? I'd like to change that up.
(Post 9731004)
no there aren't any xml's for it yet do you know if ECuflash can write back to the ecu? if so, do you have to bench it? or can it be programmed via the OBDII CAN port? |
Originally Posted by fostytou
(Post 9731437)
https://www.evolutionm.net/forums/8284214-post286.html |
(Post 9733247)
There is a Ralliart ACD ecu available for the X
It only works for the RS models though ... so not compatible with AYC. It would be nice to compare and contrast the roms though ;) I would certainly fork out some $$$ for reprogramming for road racing with someone who knew what they were doing. |
Originally Posted by Beeble
(Post 9739333)
It only works for the RS models though ... so not compatible with AYC. It would be nice to compare and contrast the roms though ;) I would certainly fork out some $$$ for reprogramming for road racing with someone who knew what they were doing. BUt i dont know tht will actually work with a stock Engine ECU. Probably yes, but i am not sure. these are the specs " The EVO ACD is a direct replacement for the factory unit making it a perfect option for group N rally series cars. Fully customisable differential maps Setup can be password protected Wheel speed sensor diagnostics Fits into standard EVO wiring Uses all standard EVO sensors Connects to GWv4 software for complete customisation 5 Modes of operation: Off, Gravel, Snow, Tarmac, Lock Start, Handbrake, Footbrake, Accel, Deccel regimes for each active mode Serial data stream for dash display Available for Mitsubishi EVO models 7-10 http://www.gems.co.uk/assets/Image/P...rol/evoACD.jpg " |
Originally Posted by evoscan
(Post 9738598)
well there were many people that didn't want the details of how to bench recover a EvoX ecu posted neither... but I posted up pictures and wiring diagrams. :)
(Post 9743603)
actually I did...
(Post 9733247)
