immobilizer bypass
I have ecuscan/ecuflash is there a setting I can use to disable the factory immobilizer.
I am installing a remote start and don't want to have to buy the flcan cause i only have one key for my evo 8 |
FAA bit for immobilizer. Chage it to disable
where and how?
Follow the instructions on this page.
Open rom in ECUFLASH and look for Immobilizer. Change bit from 1 to 0 using the "[" key |
Thanks
Got it to work |
I've ran into a problem and need some help please!!! I need to delete the immobilizer out of my rom. I downloaded a rom from the net and there are already settings in the ecu flash tables for periphery. I don't get what people keep talking about periphery0 all I see is periphery, periphery1, periphery2, and periphery3. I think I have to enter 56d2 into the periphery table listed in ecu flash when I open my Tom. Is that correct?
I have a similar problem with finding the immobiliser section. I finally got some response from the ECU. attached below.Where do I go from here?
[18:57:07.582] sending init sequence 2 [18:57:07.582] got 0xF0 response instead of 0x11 [18:57:07.582] sending init sequence 3 [18:57:07.582] error sending init sequence 3 [18:57:07.582] interface close [18:57:24.340] using metadata XML ID read_evo5 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_evo5.xml [18:57:24.356] J2534 API Version: 04.04 [18:57:24.356] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10 [18:57:24.356] Device Firmware Version: 1.17.4877 [18:57:24.356] Device Serial Number: TAgZglqv [18:57:27.340] sending init sequence 2 [18:57:27.340] got 0x11 response [18:57:27.340] sending init sequence 3 [18:57:27.701] entering bootloader [18:57:27.701] sending kernel size (2029) [18:57:27.701] sending kernel load address (0x0000F000) [18:57:27.716] uploading kernel [18:57:28.060] verifying kernel checksum response [18:57:28.060] kernel valid [18:57:28.280] kernel get version [18:57:28.280] kernel version is : OpenEcu Mitsubishi H8/539F Kernel V1.07 [18:57:28.280] reading kernel comm buffer size [18:57:28.295] comm buffer size set to 256 [18:57:28.295] reading kernel flash buffer size [18:57:28.300] flash buffer size set to 1024 [18:57:28.300] -- dumping ECU memory -- [18:57:28.363] kernel read area: addr: 00010000 len: 0100 [18:57:28.412] kernel read area: addr: 00010100 len: 0100 [18:57:28.460] kernel read area: addr: 00010200 len: 0100 [18:57:28.512] kernel read area: addr: 00010300 len: 0100 [18:57:28.560] kernel read area: addr: 00010400 len: 0100 [18:57:28.608] kernel read area: addr: 00010500 len: 0100 [18:57:28.671] kernel read area: addr: 00010600 len: 0100 [18:57:28.718] kernel read area: addr: 00010700 len: 0100 [18:57:28.765] kernel read area: addr: 00010800 len: 0100 [18:57:28.816] kernel read area: addr: 00010900 len: 0100 [18:57:28.863] kernel read area: addr: 00010A00 len: 0100 [18:57:28.927] kernel read area: addr: 00010B00 len: 0100 [18:57:28.974] kernel read area: addr: 00010C00 len: 0100 [18:57:29.025] kernel read area: addr: 00010D00 len: 0100 [18:57:29.072] kernel read area: addr: 00010E00 len: 0100 [18:57:29.119] kernel read area: addr: 00010F00 len: 0100 [18:57:29.228] kernel read area: addr: 00011000 len: 0100 [18:57:29.275] kernel read area: addr: 00011100 len: 0100 [18:57:29.338] kernel read area: addr: 00011200 len: 0100 [18:57:29.385] kernel read area: addr: 00011300 len: 0100 [18:57:29.434] kernel read area: addr: 00011400 len: 0100 [18:57:29.481] kernel read area: addr: 00011500 len: 0100 [18:57:29.528] kernel read area: addr: 00011600 len: 0100 [18:57:29.591] kernel read area: addr: 00011700 len: 0100 [18:57:29.637] kernel read area: addr: 00011800 len: 0100 [18:57:29.684] kernel read area: addr: 00011900 len: 0100 [18:57:29.747] kernel read area: addr: 00011A00 len: 0100 [18:57:29.794] kernel read area: addr: 00011B00 len: 0100 [18:57:29.835] kernel read area: addr: 00011C00 len: 0100 [18:57:29.898] kernel read area: addr: 00011D00 len: 0100 [18:57:29.945] kernel read area: addr: 00011E00 len: 0100 [18:57:29.992] kernel read area: addr: 00011F00 len: 0100 [18:57:30.101] kernel read area: addr: 00012000 len: 0100 [18:57:30.148] kernel read area: addr: 00012100 len: 0100 [18:57:30.195] kernel read area: addr: 00012200 len: 0100 [18:57:30.257] kernel read area: addr: 00012300 len: 0100 [18:57:30.304] kernel read area: addr: 00012400 len: 0100 [18:57:30.351] kernel read area: addr: 00012500 len: 0100 [18:57:30.398] kernel read area: addr: 00012600 len: 0100 [18:57:30.460] kernel read area: addr: 00012700 len: 0100 [18:57:30.507] kernel read area: addr: 00012800 len: 0100 [18:57:30.554] kernel read area: addr: 00012900 len: 0100 [18:57:30.601] kernel read area: addr: 00012A00 len: 0100 [18:57:30.663] kernel read area: addr: 00012B00 len: 0100 [18:57:30.710] kernel read area: addr: 00012C00 len: 0100 [18:57:30.757] kernel read area: addr: 00012D00 len: 0100 [18:57:30.820] kernel read area: addr: 00012E00 len: 0100 [18:57:30.866] kernel read area: addr: 00012F00 len: 0100 [18:57:30.913] kernel read area: addr: 00013000 len: 0100 [18:57:30.961] kernel read area: addr: 00013100 len: 0100 [18:57:31.023] kernel read area: addr: 00013200 len: 0100 [18:57:31.060] kernel read area: addr: 00013300 len: 0100 [18:57:31.123] kernel read area: addr: 00013400 len: 0100 [18:57:31.175] kernel read area: addr: 00013500 len: 0100 [18:57:31.222] kernel read area: addr: 00013600 len: 0100 [18:57:31.269] kernel read area: addr: 00013700 len: 0100 [18:57:31.315] kernel read area: addr: 00013800 len: 0100 [18:57:31.378] kernel read area: addr: 00013900 len: 0100 [18:57:31.425] kernel read area: addr: 00013A00 len: 0100 [18:57:31.472] kernel read area: addr: 00013B00 len: 0100 [18:57:31.519] kernel read area: addr: 00013C00 len: 0100 [18:57:31.581] kernel read area: addr: 00013D00 len: 0100 [18:57:31.628] kernel read area: addr: 00013E00 len: 0100 [18:57:31.675] kernel read area: addr: 00013F00 len: 0100 [18:57:31.784] kernel read area: addr: 00014000 len: 0100 [18:57:31.831] kernel read area: addr: 00014100 len: 0100 [18:57:31.893] kernel read area: addr: 00014200 len: 0100 [18:57:31.940] kernel read area: addr: 00014300 len: 0100 [18:57:31.987] kernel read area: addr: 00014400 len: 0100 [18:57:32.034] kernel read area: addr: 00014500 len: 0100 [18:57:32.097] kernel read area: addr: 00014600 len: 0100 [18:57:32.143] kernel read area: addr: 00014700 len: 0100 [18:57:32.190] kernel read area: addr: 00014800 len: 0100 [18:57:32.237] kernel read area: addr: 00014900 len: 0100 [18:57:32.300] kernel read area: addr: 00014A00 len: 0100 [18:57:32.346] kernel read area: addr: 00014B00 len: 0100 [18:57:32.393] kernel read area: addr: 00014C00 len: 0100 [18:57:32.440] kernel read area: addr: 00014D00 len: 0100 [18:57:32.503] kernel read area: addr: 00014E00 len: 0100 [18:57:32.550] kernel read area: addr: 00014F00 len: 0100 [18:57:32.659] kernel read area: addr: 00015000 len: 0100 [18:57:32.706] kernel read area: addr: 00015100 len: 0100 [18:57:32.753] kernel read area: addr: 00015200 len: 0100 [18:57:32.799] kernel read area: addr: 00015300 len: 0100 [18:57:32.862] kernel read area: addr: 00015400 len: 0100 [18:57:32.909] kernel read area: addr: 00015500 len: 0100 [18:57:32.956] kernel read area: addr: 00015600 len: 0100 [18:57:33.003] kernel read area: addr: 00015700 len: 0100 [18:57:33.066] kernel read area: addr: 00015800 len: 0100 [18:57:33.113] kernel read area: addr: 00015900 len: 0100 [18:57:33.159] kernel read area: addr: 00015A00 len: 0100 [18:57:33.206] kernel read area: addr: 00015B00 len: 0100 [18:57:33.269] kernel read area: addr: 00015C00 len: 0100 [18:57:33.320] kernel read area: addr: 00015D00 len: 0100 [18:57:33.367] kernel read area: addr: 00015E00 len: 0100 [18:57:33.413] kernel read area: addr: 00015F00 len: 0100 [18:57:33.523] kernel read area: addr: 00016000 len: 0100 [18:57:33.570] kernel read area: addr: 00016100 len: 0100 [18:57:33.617] kernel read area: addr: 00016200 len: 0100 [18:57:33.679] kernel read area: addr: 00016300 len: 0100 [18:57:33.729] kernel read area: addr: 00016400 len: 0100 [18:57:33.776] kernel read area: addr: 00016500 len: 0100 [18:57:33.823] kernel read area: addr: 00016600 len: 0100 [18:57:33.886] kernel read area: addr: 00016700 len: 0100 [18:57:33.933] kernel read area: addr: 00016800 len: 0100 [18:57:33.979] kernel read area: addr: 00016900 len: 0100 [18:57:34.026] kernel read area: addr: 00016A00 len: 0100 [18:57:34.089] kernel read area: addr: 00016B00 len: 0100 [18:57:34.136] kernel read area: addr: 00016C00 len: 0100 [18:57:34.183] kernel read area: addr: 00016D00 len: 0100 [18:57:34.229] kernel read area: addr: 00016E00 len: 0100 [18:57:34.292] kernel read area: addr: 00016F00 len: 0100 [18:57:34.386] kernel read area: addr: 00017000 len: 0100 [18:57:34.448] kernel read area: addr: 00017100 len: 0100 [18:57:34.495] kernel read area: addr: 00017200 len: 0100 [18:57:34.542] kernel read area: addr: 00017300 len: 0100 [18:57:34.589] kernel read area: addr: 00017400 len: 0100 [18:57:34.652] kernel read area: addr: 00017500 len: 0100 [18:57:34.699] kernel read area: addr: 00017600 len: 0100 [18:57:34.746] kernel read area: addr: 00017700 len: 0100 [18:57:34.793] kernel read area: addr: 00017800 len: 0100 [18:57:34.840] kernel read area: addr: 00017900 len: 0100 [18:57:34.896] kernel read area: addr: 00017A00 len: 0100 [18:57:34.950] kernel read area: addr: 00017B00 len: 0100 [18:57:34.997] kernel read area: addr: 00017C00 len: 0100 [18:57:35.044] kernel read area: addr: 00017D00 len: 0100 [18:57:35.106] kernel read area: addr: 00017E00 len: 0100 [18:57:35.153] kernel read area: addr: 00017F00 len: 0100 [18:57:35.262] kernel read area: addr: 00018000 len: 0100 [18:57:35.309] kernel read area: addr: 00018100 len: 0100 [18:57:35.356] kernel read area: addr: 00018200 len: 0100 [18:57:35.419] kernel read area: addr: 00018300 len: 0100 [18:57:35.466] kernel read area: addr: 00018400 len: 0100 [18:57:35.512] kernel read area: addr: 00018500 len: 0100 [18:57:35.559] kernel read area: addr: 00018600 len: 0100 [18:57:35.622] kernel read area: addr: 00018700 len: 0100 [18:57:35.669] kernel read area: addr: 00018800 len: 0100 [18:57:35.715] kernel read area: addr: 00018900 len: 0100 [18:57:35.762] kernel read area: addr: 00018A00 len: 0100 [18:57:35.825] kernel read area: addr: 00018B00 len: 0100 [18:57:35.872] kernel read area: addr: 00018C00 len: 0100 [18:57:35.919] kernel read area: addr: 00018D00 len: 0100 [18:57:35.966] kernel read area: addr: 00018E00 len: 0100 [18:57:36.028] kernel read area: addr: 00018F00 len: 0100 [18:57:36.122] kernel read area: addr: 00019000 len: 0100 [18:57:36.185] kernel read area: addr: 00019100 len: 0100 [18:57:36.232] kernel read area: addr: 00019200 len: 0100 [18:57:36.278] kernel read area: addr: 00019300 len: 0100 [18:57:36.325] kernel read area: addr: 00019400 len: 0100 [18:57:36.388] kernel read area: addr: 00019500 len: 0100 [18:57:36.435] kernel read area: addr: 00019600 len: 0100 [18:57:36.481] kernel read area: addr: 00019700 len: 0100 [18:57:36.544] kernel read area: addr: 00019800 len: 0100 [18:57:36.591] kernel read area: addr: 00019900 len: 0100 [18:57:36.638] kernel read area: addr: 00019A00 len: 0100 [18:57:36.685] kernel read area: addr: 00019B00 len: 0100 [18:57:36.747] kernel read area: addr: 00019C00 len: 0100 [18:57:36.784] kernel read area: addr: 00019D00 len: 0100 [18:57:36.847] kernel read area: addr: 00019E00 len: 0100 [18:57:36.895] kernel read area: addr: 00019F00 len: 0100 [18:57:37.330] kernel read area: addr: 00020000 len: 0100 [18:57:37.377] kernel read area: addr: 00020100 len: 0100 [18:57:37.424] kernel read area: addr: 00020200 len: 0100 [18:57:37.471] kernel read area: addr: 00020300 len: 0100 [18:57:37.533] kernel read area: addr: 00020400 len: 0100 [18:57:37.570] kernel read area: addr: 00020500 len: 0100 [18:57:37.633] kernel read area: addr: 00020600 len: 0100 [18:57:37.679] kernel read area: addr: 00020700 len: 0100 [18:57:37.726] kernel read area: addr: 00020800 len: 0100 [18:57:37.773] kernel read area: addr: 00020900 len: 0100 [18:57:37.836] kernel read area: addr: 00020A00 len: 0100 [18:57:37.883] kernel read area: addr: 00020B00 len: 0100 [18:57:37.930] kernel read area: addr: 00020C00 len: 0100 [18:57:37.992] kernel read area: addr: 00020D00 len: 0100 [18:57:38.039] kernel read area: addr: 00020E00 len: 0100 [18:57:38.086] kernel read area: addr: 00020F00 len: 0100 [18:57:38.195] kernel read area: addr: 00021000 len: 0100 [18:57:38.242] kernel read area: addr: 00021100 len: 0100 [18:57:38.289] kernel read area: addr: 00021200 len: 0100 [18:57:38.351] kernel read area: addr: 00021300 len: 0100 [18:57:38.398] kernel read area: addr: 00021400 len: 0100 [18:57:38.445] kernel read area: addr: 00021500 len: 0100 [18:57:38.492] kernel read area: addr: 00021600 len: 0100 [18:57:38.554] kernel read area: addr: 00021700 len: 0100 [18:57:38.601] kernel read area: addr: 00021800 len: 0100 [18:57:38.648] kernel read area: addr: 00021900 len: 0100 [18:57:38.695] kernel read area: addr: 00021A00 len: 0100 [18:57:38.758] kernel read area: addr: 00021B00 len: 0100 [18:57:38.804] kernel read area: addr: 00021C00 len: 0100 [18:57:38.851] kernel read area: addr: 00021D00 len: 0100 [18:57:38.898] kernel read area: addr: 00021E00 len: 0100 [18:57:38.961] kernel read area: addr: 00021F00 len: 0100 [18:57:39.055] kernel read area: addr: 00022000 len: 0100 [18:57:39.118] kernel read area: addr: 00022100 len: 0100 [18:57:39.164] kernel read area: addr: 00022200 len: 0100 [18:57:39.211] kernel read area: addr: 00022300 len: 0100 [18:57:39.258] kernel read area: addr: 00022400 len: 0100 [18:57:39.321] kernel read area: addr: 00022500 len: 0100 [18:57:39.367] kernel read area: addr: 00022600 len: 0100 [18:57:39.414] kernel read area: addr: 00022700 len: 0100 [18:57:39.461] kernel read area: addr: 00022800 len: 0100 [18:57:39.524] kernel read area: addr: 00022900 len: 0100 [18:57:39.570] kernel read area: addr: 00022A00 len: 0100 [18:57:39.617] kernel read area: addr: 00022B00 len: 0100 [18:57:39.680] kernel read area: addr: 00022C00 len: 0100 [18:57:39.727] kernel read area: addr: 00022D00 len: 0100 [18:57:39.774] kernel read area: addr: 00022E00 len: 0100 [18:57:39.820] kernel read area: addr: 00022F00 len: 0100 [18:57:39.930] kernel read area: addr: 00023000 len: 0100 [18:57:39.977] kernel read area: addr: 00023100 len: 0100 [18:57:40.040] kernel read area: addr: 00023200 len: 0100 [18:57:40.086] kernel read area: addr: 00023300 len: 0100 [18:57:40.133] kernel read area: addr: 00023400 len: 0100 [18:57:40.180] kernel read area: addr: 00023500 len: 0100 [18:57:40.242] kernel read area: addr: 00023600 len: 0100 [18:57:40.289] kernel read area: addr: 00023700 len: 0100 [18:57:40.336] kernel read area: addr: 00023800 len: 0100 [18:57:40.383] kernel read area: addr: 00023900 len: 0100 [18:57:40.446] kernel read area: addr: 00023A00 len: 0100 [18:57:40.492] kernel read area: addr: 00023B00 len: 0100 [18:57:40.539] kernel read area: addr: 00023C00 len: 0100 [18:57:40.586] kernel read area: addr: 00023D00 len: 0100 [18:57:40.649] kernel read area: addr: 00023E00 len: 0100 [18:57:40.700] kernel read area: addr: 00023F00 len: 0100 [18:57:40.794] kernel read area: addr: 00024000 len: 0100 [18:57:40.840] kernel read area: addr: 00024100 len: 0100 [18:57:40.903] kernel read area: addr: 00024200 len: 0100 [18:57:40.950] kernel read area: addr: 00024300 len: 0100 [18:57:40.997] kernel read area: addr: 00024400 len: 0100 [18:57:41.046] kernel read area: addr: 00024500 len: 0100 [18:57:41.094] kernel read area: addr: 00024600 len: 0100 [18:57:41.156] kernel read area: addr: 00024700 len: 0100 [18:57:41.203] kernel read area: addr: 00024800 len: 0100 [18:57:41.250] kernel read area: addr: 00024900 len: 0100 [18:57:41.297] kernel read area: addr: 00024A00 len: 0100 [18:57:41.359] kernel read area: addr: 00024B00 len: 0100 [18:57:41.406] kernel read area: addr: 00024C00 len: 0100 [18:57:41.453] kernel read area: addr: 00024D00 len: 0100 [18:57:41.500] kernel read area: addr: 00024E00 len: 0100 [18:57:41.547] kernel read area: addr: 00024F00 len: 0100 [18:57:41.656] kernel read area: addr: 00025000 len: 0100 [18:57:41.703] kernel read area: addr: 00025100 len: 0100 [18:57:41.766] kernel read area: addr: 00025200 len: 0100 [18:57:41.812] kernel read area: addr: 00025300 len: 0100 [18:57:41.859] kernel read area: addr: 00025400 len: 0100 [18:57:41.906] kernel read area: addr: 00025500 len: 0100 [18:57:41.969] kernel read area: addr: 00025600 len: 0100 [18:57:42.017] kernel read area: addr: 00025700 len: 0100 [18:57:42.066] kernel read area: addr: 00025800 len: 0100 [18:57:42.113] kernel read area: addr: 00025900 len: 0100 [18:57:42.160] kernel read area: addr: 00025A00 len: 0100 [18:57:42.207] kernel read area: addr: 00025B00 len: 0100 [18:57:42.267] kernel read area: addr: 00025C00 len: 0100 [18:57:42.313] kernel read area: addr: 00025D00 len: 0100 [18:57:42.360] kernel read area: addr: 00025E00 len: 0100 [18:57:42.423] kernel read area: addr: 00025F00 len: 0100 [18:57:42.516] kernel read area: addr: 00026000 len: 0100 [18:57:42.564] kernel read area: addr: 00026100 len: 0100 [18:57:42.627] kernel read area: addr: 00026200 len: 0100 [18:57:42.674] kernel read area: addr: 00026300 len: 0100 [18:57:42.720] kernel read area: addr: 00026400 len: 0100 [18:57:42.768] kernel read area: addr: 00026500 len: 0100 [18:57:42.830] kernel read area: addr: 00026600 len: 0100 [18:57:42.877] kernel read area: addr: 00026700 len: 0100 [18:57:42.924] kernel read area: addr: 00026800 len: 0100 [18:57:42.971] kernel read area: addr: 00026900 len: 0100 [18:57:43.018] kernel read area: addr: 00026A00 len: 0100 [18:57:43.080] kernel read area: addr: 00026B00 len: 0100 [18:57:43.127] kernel read area: addr: 00026C00 len: 0100 [18:57:43.174] kernel read area: addr: 00026D00 len: 0100 [18:57:43.221] kernel read area: addr: 00026E00 len: 0100 [18:57:43.283] kernel read area: addr: 00026F00 len: 0100 [18:57:43.377] kernel read area: addr: 00027000 len: 0100 [18:57:43.440] kernel read area: addr: 00027100 len: 0100 [18:57:43.486] kernel read area: addr: 00027200 len: 0100 [18:57:43.533] kernel read area: addr: 00027300 len: 0100 [18:57:43.580] kernel read area: addr: 00027400 len: 0100 [18:57:43.643] kernel read area: addr: 00027500 len: 0100 [18:57:43.690] kernel read area: addr: 00027600 len: 0100 [18:57:43.736] kernel read area: addr: 00027700 len: 0100 [18:57:43.783] kernel read area: addr: 00027800 len: 0100 [18:57:43.846] kernel read area: addr: 00027900 len: 0100 [18:57:43.892] kernel read area: addr: 00027A00 len: 0100 [18:57:43.939] kernel read area: addr: 00027B00 len: 0100 [18:57:43.987] kernel read area: addr: 00027C00 len: 0100 [18:57:44.049] kernel read area: addr: 00027D00 len: 0100 [18:57:44.100] kernel read area: addr: 00027E00 len: 0100 [18:57:44.147] kernel read area: addr: 00027F00 len: 0100 [18:57:44.240] kernel read area: addr: 00028000 len: 0100 [18:57:44.303] kernel read area: addr: 00028100 len: 0100 [18:57:44.350] kernel read area: addr: 00028200 len: 0100 [18:57:44.397] kernel read area: addr: 00028300 len: 0100 [18:57:44.444] kernel read area: addr: 00028400 len: 0100 [18:57:44.506] kernel read area: addr: 00028500 len: 0100 [18:57:44.553] kernel read area: addr: 00028600 len: 0100 [18:57:44.600] kernel read area: addr: 00028700 len: 0100 [18:57:44.662] kernel read area: addr: 00028800 len: 0100 [18:57:44.709] kernel read area: addr: 00028900 len: 0100 [18:57:44.756] kernel read area: addr: 00028A00 len: 0100 [18:57:44.803] kernel read area: addr: 00028B00 len: 0100 [18:57:44.865] kernel read area: addr: 00028C00 len: 0100 [18:57:44.912] kernel read area: addr: 00028D00 len: 0100 [18:57:44.964] kernel read area: addr: 00028E00 len: 0100 [18:57:45.011] kernel read area: addr: 00028F00 len: 0100 [18:57:45.120] kernel read area: addr: 00029000 len: 0100 [18:57:45.167] kernel read area: addr: 00029100 len: 0100 [18:57:45.214] kernel read area: addr: 00029200 len: 0100 [18:57:45.276] kernel read area: addr: 00029300 len: 0100 [18:57:45.323] kernel read area: addr: 00029400 len: 0100 [18:57:45.370] kernel read area: addr: 00029500 len: 0100 [18:57:45.417] kernel read area: addr: 00029600 len: 0100 [18:57:45.479] kernel read area: addr: 00029700 len: 0100 [18:57:45.526] kernel read area: addr: 00029800 len: 0100 [18:57:45.573] kernel read area: addr: 00029900 len: 0100 [18:57:45.620] kernel read area: addr: 00029A00 len: 0100 [18:57:45.683] kernel read area: addr: 00029B00 len: 0100 [18:57:45.730] kernel read area: addr: 00029C00 len: 0100 [18:57:45.777] kernel read area: addr: 00029D00 len: 0100 [18:57:45.823] kernel read area: addr: 00029E00 len: 0100 [18:57:45.886] kernel read area: addr: 00029F00 len: 0100 [18:57:45.985] kernel read area: addr: 0002A000 len: 0100 [18:57:46.032] kernel read area: addr: 0002A100 len: 0100 [18:57:46.094] kernel read area: addr: 0002A200 len: 0100 [18:57:46.141] kernel read area: addr: 0002A300 len: 0100 [18:57:46.188] kernel read area: addr: 0002A400 len: 0100 [18:57:46.235] kernel read area: addr: 0002A500 len: 0100 [18:57:46.297] kernel read area: addr: 0002A600 len: 0100 [18:57:46.344] kernel read area: addr: 0002A700 len: 0100 [18:57:46.391] kernel read area: addr: 0002A800 len: 0100 [18:57:46.438] kernel read area: addr: 0002A900 len: 0100 [18:57:46.500] kernel read area: addr: 0002AA00 len: 0100 [18:57:46.547] kernel read area: addr: 0002AB00 len: 0100 [18:57:46.594] kernel read area: addr: 0002AC00 len: 0100 [18:57:46.641] kernel read area: addr: 0002AD00 len: 0100 [18:57:46.703] kernel read area: addr: 0002AE00 len: 0100 [18:57:46.750] kernel read area: addr: 0002AF00 len: 0100 [18:57:46.850] kernel read area: addr: 0002B000 len: 0100 [18:57:46.913] kernel read area: addr: 0002B100 len: 0100 [18:57:46.950] kernel read area: addr: 0002B200 len: 0100 [18:57:47.012] kernel read area: addr: 0002B300 len: 0100 [18:57:47.059] kernel read area: addr: 0002B400 len: 0100 [18:57:47.106] kernel read area: addr: 0002B500 len: 0100 [18:57:47.153] kernel read area: addr: 0002B600 len: 0100 [18:57:47.216] kernel read area: addr: 0002B700 len: 0100 [18:57:47.263] kernel read area: addr: 0002B800 len: 0100 [18:57:47.309] kernel read area: addr: 0002B900 len: 0100 [18:57:47.372] kernel read area: addr: 0002BA00 len: 0100 [18:57:47.419] kernel read area: addr: 0002BB00 len: 0100 [18:57:47.466] kernel read area: addr: 0002BC00 len: 0100 [18:57:47.512] kernel read area: addr: 0002BD00 len: 0100 [18:57:47.575] kernel read area: addr: 0002BE00 len: 0100 [18:57:47.622] kernel read area: addr: 0002BF00 len: 0100 [18:57:47.716] kernel read area: addr: 0002C000 len: 0100 [18:57:47.778] kernel read area: addr: 0002C100 len: 0100 [18:57:47.825] kernel read area: addr: 0002C200 len: 0100 [18:57:47.872] kernel read area: addr: 0002C300 len: 0100 [18:57:47.934] kernel read area: addr: 0002C400 len: 0100 [18:57:47.981] kernel read area: addr: 0002C500 len: 0100 [18:57:48.028] kernel read area: addr: 0002C600 len: 0100 [18:57:48.075] kernel read area: addr: 0002C700 len: 0100 [18:57:48.137] kernel read area: addr: 0002C800 len: 0100 [18:57:48.184] kernel read area: addr: 0002C900 len: 0100 [18:57:48.231] kernel read area: addr: 0002CA00 len: 0100 [18:57:48.278] kernel read area: addr: 0002CB00 len: 0100 [18:57:48.340] kernel read area: addr: 0002CC00 len: 0100 [18:57:48.387] kernel read area: addr: 0002CD00 len: 0100 [18:57:48.434] kernel read area: addr: 0002CE00 len: 0100 [18:57:48.481] kernel read area: addr: 0002CF00 len: 0100 [18:57:48.700] kernel read area: addr: 0002F000 len: 0100 [18:57:48.753] kernel read area: addr: 0002F100 len: 0100 [18:57:48.800] kernel read area: addr: 0002F200 len: 0100 [18:57:48.847] kernel read area: addr: 0002F300 len: 0100 [18:57:48.910] kernel read area: addr: 0002F400 len: 0100 [18:57:48.957] kernel read area: addr: 0002F500 len: 0100 [18:57:49.004] kernel read area: addr: 0002F600 len: 0100 [18:57:49.051] kernel read area: addr: 0002F700 len: 0100 [18:57:49.114] kernel read area: addr: 0002F800 len: 0100 [18:57:49.163] kernel read area: addr: 0002F900 len: 0100 [18:57:49.210] kernel read area: addr: 0002FA00 len: 0100 [18:57:49.257] kernel read area: addr: 0002FB00 len: 0100 [18:57:49.319] kernel read area: addr: 0002FC00 len: 0100 [18:57:49.366] kernel read area: addr: 0002FD00 len: 0100 [18:57:49.413] kernel read area: addr: 0002FE00 len: 0100 [18:57:49.460] kernel read area: addr: 0002FF00 len: 0100 [18:57:49.523] interface close [18:57:52.434] using metadata XML ID 22060000 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/eclipse/22060000.xml Any help would be most appreciated. |
You're working way too hard. Corrent ROMs have a section where you enter any immobilizer code you want (or disable).
Hi Kaj,
I am a total newby with this. I have a MH7202 rom in an ecu on a 6g72 engine in an MK Triton. I can't find any xml tables for this setup. Long story short, I fitted a 6g72 engine and purchased an ECU separately. Then discovered that the ECU needs an immobiliser input. Bought a 1.3U cable, couldn't get any satisfaction, then on advice bought a 2.0 cable and this is where I am at. |
It appears that i need a definition file? For ecuflash to translate the image from the rom. I think i might try a 6g72 magna xml file and see where i go from there. I can't find a triton 6g72 xml file anywhere. All help welcome.
