getting fic 2150 to idle 14.7 not 11.5
Car runs great on the throttle cruising around at 14.7 with tephra mod and John Bradleys scaling of 1624. I tried 1720 and car seems to want to shut down. My trims are -12. Would like to get those close to 0.Any ideas.I also have cams. Im running sd also.
Have you applied the minimum IPW patch? If not, try that and lower your minimum IPW.
My minimum ipw is .040 I ried 1.02 and car wouldnt start.Should I try to go lower.That is pretty low for those injectors,
That's probably too low, I have mine set to 1.088 on my 93 octane map and 1.144 on E85.
ok good info,thanks
I’m having the same issue
Ok I have also fic 2150 I saw one you guys said that there ipw patch where can I find that patch I’m also running thepra v7 I have s3 cams and I had try to change the ipw 1.400 car wouldn’t start even if change it to 0.060 to see if the car would start and it wouldn’t any ideas
