A bunch of load calculation related maps
Hi Peeps,
Been sitting on these for a while, they basically control how load is calculated, they are a bit of a work in progress, so the names might change as we work them out properly: 53040010: Code:
<table name="ECT Compensation for Load" category="Load" address="55004" type="2D" scaling="Percent128"> https://www.evolutionm.net/forums/09...l#post10494316 If you want to stop the sawtooth affect of load @ WOT, change the "Load multiplier end when TPS decreased by % (hysteresis)" map from 0.4% to something higher. Goog luck :) Regards David |
Thanks T.
I was missing Baro16 in my 53040010 def (on my computer), but I realized that it's on my site. Code:
<scaling name="Baro16" units="bar" toexpr="x/200" frexpr="x*200" format="%.3f" min="0" max="1.1" inc="0.001" storagetype="uint16" endian="big"/> |
I've been setting the "Load Multiplier when TSP Increase by %" and it's sister "decreasing" one to 1.2% for a long time now.
Again, thanks Tephra. (He sent me that map a long time ago.) |
Brilliant, thanks for this, tephra.
Golden, I've defined "Load Ramp Rate #1 (Load > 75)" on your online DB, and have populated it for the most popular Ralliart ROMs. I've prioritised this because of the recent discovery that the RA dixie-cup turbo spools way faster than the Load Ramp Rate can accommodate. Not good. The fix, though, is awesome. No more spool-up knock. {thumbup} Rich |
U guys speak Latin....I'm just trying to learn. On top of that, I'm on a different program too! I need to switch from Cobb ATR.
Richard, I got my car back so I'm gonna need ur expertise again when the time comes. Right now, I'm just redoing my fuel map so I don't get the damn code "lean mixture" again. My boost is almost set though. |
5268 series pretty please...
Originally Posted by ScottSpeed21
(Post 10501114)
He meant to say 56890013 :D |
You realize that I always do 5557 first, right? ;)
Have read Richard's post and started tweaking Load Ramp Rate #1 with some positive results.
David, would you be able provide more information on the Load Ramp Rate #2 to #4? Under what condition are they used? |
Could someone kindly help me to find the addresses for 52360018?
Thanks. |
Addresses for 58020005 2012 MR please :-)
The two most important ones should already be up on goldenevo.com. Those are:
Load multiplier end when TPS decreased by % (hysteresis) Load Ramp Rate #1 Rich |
Can I have these defs for 55570005 please :)
I'm more interested in the Load Ramp Down w/ the associated MIVEC Overlap....
sstevojr, here is what I have managed to define for the 55570005 ROM. Not sure if you are using this, else just let me know which ROM ID you are on.
Code:
<scaling name="ReverseInterpolated_Percent255_1byte" units="%" toexpr="100*(1-(x/255))" frexpr="255*(1-(x/100))" format="%.0f" min="0" max="100" inc="1" storagetype="uint8" endian="big"/> |
