EvoScan J2534 Read Error - 16
Hi guys!
I recently updated to EvoScan v2.9.0023 Since then I have started getting read errors when trying to display DTCs. I then reinstalled EvoScan 2.8 and have been receiving the same type problems. The vehicle is a Mitsubishi Evo8 It previously had rom ID: 92660006 Now has Tephra v7 96530706 Engine light has come on after the Tephra mod. and that's the reason I need to check DTCs on it. Code:
Log from EvoScan: Before recently, I haven't had any problems reading DTCs with EvoScan since I started using it 3-4 years ago. Have I missed configurating something? |
Forgot one very important addition to my post above:
I have no problems at all with the scanning/logging features. It's only the "Display DTC's" that is causing an issue. |
I'm having the same issue "J2534 Read Error - 16" and it doesn't dataloggs...
i've had a similar issue since update, said something about updating firmware and nothing but problems since, i've been in contact with tactrix about what could be the issue
try uninstalling ecuflash and the open port drivers and reinstalling |
Any fixes for this?
Originally Posted by rictrd
(Post 10723369)
Error: Arithmetic operation resulted in an overflow. Info: Datalogger Ended. Anyone can help? |
any update on this.
I found this: http://www.tactrix.com/index.php?opt...d=38&Itemid=61
Any updates on this error code? Ive got the same problem.....
any updates?
I get the same error on DTCs and when trying to use gauge displays. Would love to hear any resolution to this.
Same issue for me on dtc scan for my evo 8. No problems with logging or anything at all. Im new to evoscan, just downloaded yesterday. I tried to clear cel and it said error but after a min or so cel went off so its working just throwing that error. Maybe a dumb question but does anyone elses abs light flash while logging?
i had exactly the same problems after the new tactrix(force) firmware update.
sometimes it reads dtc but most of the time no. and also i am not able to log injectors duty cycle anymore. |
Same problem here, efi dtc read works normal. Abs dtc sometimes and ayc never. Using Openport 2.0 on Evo V
Anyone find a cure?
