Shot down Evo 6 ECU. Need your help.
Hi all!
Tonight i tried to tune Evo 6 RS JDM. I succesfully read the ROm from ECU, changed MUT00/MUT01 values and started to load it back to ECU. But something go wrong and i saw the pop-up error window on Evoscan. All relays under the hood strted to knocking and gauges and panel illumination starts blinking. the engine starts, but run very poor and stalling. I downloaded the stock ROM from the forum, but it don`t want to load too. All simptoms the same. ID 24430002, EcuFlash Version 1.44.4234. ROM was modified before... Not by me, i dont know who was the tuner. This is the log, i have when writing ECU [22:42:16.593] kernel version is : OpenEcu Mitsubishi H8/539FA Kernel V1.07 [22:42:16.593] reading kernel comm buffer size [22:42:16.593] comm buffer size set to 256 [22:42:16.593] reading kernel flash buffer size [22:42:16.609] flash buffer size set to 1024 [22:42:16.609] -- flashing image to ECU memory -- [22:42:17.015] -- comparing ECU flash memory pages to image file -- [22:42:17.015] seg start len ecu CRC32 img CRC32 same? [22:42:17.031] EB0 00010000 000003FF 88308BEE 69778D7B NO [22:42:17.062] EB1 00010400 000003FF 88308BEE 88308BEE YES [22:42:17.078] EB2 00010800 000003FF 88308BEE 28550154 NO [22:42:17.093] EB3 00010C00 000003FF 88308BEE 93064260 NO [22:42:17.437] EB4 00011000 00006FFF 4111D01F 6C0D834E NO [22:42:17.812] EB5 00018000 00007FFF 28B7631B 28B7631B YES [22:42:18.203] EB6 00020000 00007FFF 0F0D2815 0F0D2815 YES [22:42:18.578] EB7 00028000 00007FFF BAF68F6B BAF68F6B YES [22:42:18.578] kernel flash enable [22:42:18.593] kernel blank flash page: addr: 00011000 [22:42:18.609] erased in 1 pulse(s) [22:42:18.609] kernel write flash buffer addr: 00011000 len: 00000100 [22:42:18.656] kernel write flash buffer addr: 00011100 len: 00000100 [22:42:18.703] kernel write flash buffer addr: 00011200 len: 00000100 [22:42:18.750] kernel write flash buffer addr: 00011300 len: 00000100 [22:42:18.796] kernel commit flash addr: 00011000 len: 00000400 crc32 9191f7f7 [22:42:18.890] kernel error: programming failure [22:42:18.890] failed to commit flash at 00011000! [22:42:18.890] failure in flashing block [22:42:18.890] kernel flash disable [22:42:18.890] interface close Does anybody have any ideas how to solve this problem? Is the problem in ECU or in LapTop? I can put the new ECU in the morning, but i afraid if it will die too. Very need your help. Thank you. |
May be ECU was locked for writing?
Originally Posted by Nsk
(Post 11269640)
Hi all!
what flash cable are you using? You need OpenPort2 for the six.
Originally Posted by todd6027
(Post 11270187)
change the memmodel in the xml file and the 5 base xml from H8539F to H8539FA save the xml reopen ecuflash and try again
Originally Posted by merlin.oz
(Post 11270217)
(Post 11270187)
yhpm
Today replaced ecu with evo5 gsr one, but now i can't to read it... What the...?!
did you try both read options for 5 /6 ecu 7202f and then tme 7203f if you did check all the connections to ecu and obd socket
the flash line is open circuit
So I just tried Reflashing the Evo VI RS ECU in my Lancer GSR and I've run into the same problem, any solutions?
[15:22:39.050] J2534 API Version: 04.04 [15:22:39.050] J2534 DLL Version: 1.01.4358 Oct 10 2014 03:49:00 [15:22:39.050] Device Firmware Version: 1.15.4378 [15:22:39.050] Device Serial Number: TAefRcRg [15:22:39.884] sending init sequence 2 [15:22:39.884] got 0x11 response [15:22:39.884] sending init sequence 3 [15:22:40.228] entering bootloader [15:22:40.228] sending kernel size (1951) [15:22:40.228] sending kernel load address (0x0000F000) [15:22:40.228] uploading kernel [15:22:40.542] verifying kernel checksum response [15:22:40.542] kernel valid [15:22:40.760] kernel get version [15:22:40.760] kernel version is : OpenEcu Mitsubishi H8/539FA Kernel V1.07 [15:22:40.760] reading kernel comm buffer size [15:22:40.776] comm buffer size set to 256 [15:22:40.776] reading kernel flash buffer size [15:22:40.776] flash buffer size set to 1024 [15:22:40.792] -- flashing image to ECU memory -- [15:22:41.198] -- comparing ECU flash memory pages to image file -- [15:22:41.198] seg start len ecu CRC32 img CRC32 same? [15:22:41.214] EB0 00010000 00000400 38BEDF39 38BEDF39 YES [15:22:41.229] EB1 00010400 00000400 B83AFFF4 B83AFFF4 YES [15:22:41.245] EB2 00010800 00000400 45F86304 44963F2B NO [15:22:41.268] EB3 00010C00 00000400 9F238897 9F238897 YES [15:22:41.605] EB4 00011000 00007000 06D5D2EC 9FB228B1 NO [15:22:41.978] EB5 00018000 00008000 754D7E8F 754D7E8F YES [15:22:42.369] EB6 00020000 00008000 F862C931 F862C931 YES [15:22:42.759] EB7 00028000 00008000 25DA4E5F 25DA4E5F YES [15:22:42.759] kernel flash enable [15:22:42.759] kernel blank flash page: addr: 00011000 [15:22:42.775] erased in 1 pulse(s) [15:22:42.775] kernel write flash buffer addr: 00011000 len: 00000100 [15:22:42.822] kernel write flash buffer addr: 00011100 len: 00000100 [15:22:42.869] kernel write flash buffer addr: 00011200 len: 00000100 [15:22:42.916] kernel write flash buffer addr: 00011300 len: 00000100 [15:22:42.963] kernel commit flash addr: 00011000 len: 00000400 crc32 9191f7f7 [15:22:43.041] kernel error: programming failure [15:22:43.041] failed to commit flash at 00011000! [15:22:43.041] failure in flashing block [15:22:43.041] kernel flash disable [15:22:43.056] interface close note, now when I start the car the idle is all jumpy, and i can hear clicking from behind the dashboard. |
Follow Todd's advice plus run ecu unlocker before trying to flash again.
If I am flashing an Evo VI ECU and not sure which chip is in it, I try just changing 1 cell and flashing it back. If the memmodel is wrong it wont flash. |
ECU Unlocker makes no difference.
Ive just finished reading this thread, seems like i'm experiencing the exact same thing as this guy, and he ended up with a doorstop :/ http://www.geekmapped.com/forums/showthread.php?t=3442 |
This is where I'm at currently. Relays go mad when I turn the key to on, can test write a ROM. but when I try to write it properly I get this:
[11:26:01.560] kernel flash enable [11:26:01.560] kernel blank flash page: addr: 0002C000 [11:26:02.029] erased in 2 pulse(s) [11:26:02.029] kernel write flash buffer addr: 0002C000 len: 00000100 [11:26:02.076] kernel write flash buffer addr: 0002C100 len: 00000100 [11:26:02.123] kernel write flash buffer addr: 0002C200 len: 00000100 [11:26:02.170] kernel write flash buffer addr: 0002C300 len: 00000100 [11:26:02.217] kernel commit flash addr: 0002C000 len: 00000400 crc32 7728161e [11:26:02.248] kernel debug: [11:26:02.248] [B0] FF FF 00 32 F9 F6 00 14 C0 00 F0 00 FF FF C0 7F 71 B8 02 [11:26:02.248] kernel error: programming failure [11:26:02.248] failed to commit flash at 0002C000! [11:26:02.248] failure in flashing block [11:26:02.248] kernel flash disable [11:26:02.248] interface close Think I bricked it.. Somehow. |
