new livemap client
https://github.com/DowJhob/Evo-live-map/releases https://discord.gg/MSFSn5ywRv Application for editing mitsubishi controller tables on the fly in RAM. Works with OpenPort1.3 and OpenPort2.0. All descriptions of RAM tables are stored in xml files as in ecuflash, new attributes have been added to table descriptions indicating the location of tables in the controller's RAM. Sample: <table name="High Octane Fuel Map" category="Fuel" address="37b4d" type="3D" level="4" swapxy="true" scaling="AFR" RAM_addr="FFFFA04D"> <table name="Load" address="4fdc" type="X Axis" elements="18" scaling="Load" RAM_mut_number="0x00"/> <table name="RPM" address="4fb4" type="Y Axis" elements="15" scaling="RPM" RAM_mut_number="0x02"/> </table> RAM_addr table address in RAM, RAM_mut_number number MUT table in RAM The program itself detects the type of interface J2534 or FTDI adapter, if there are installed drivers. When the start button is pressed, an attempt is made to connect to the controller using an alternative protocol and, if successful, the internal ID is read, then the application by the mask of the ID number tries to find and read the first found xml calibration file containing the ID number in the name, if not, the file search window opens. And then all tables available for editing in RAM will be opened. obsolete - The xdf directory contains patches for tunerpto https://www.tunerpro.net/ all patches will be replaced with ecuflash style Short description: The Mitsu controller has a built-in DMA protocol, its implementation was recently written by Orion4096 aka Nanner55 GitHub, but the first was jcsbanks in 2008, these topics are on evo, also in the evo10 controller there is a DMA protocol that modified tephra (I have not yet finished it implemented). The jcsbanks protocol is selected by default, all DMA tephra v7 use it. At the moment, 90550001, 80770001, 96262709, and 96532706, 88592715 have been tested on jcsbanks, I will correct it when there are testers, 90550001 and 88590015 have been tested on nanner55. Patcher - works on the same xml as ecuflash but can apply all patches as a group, also as part of the patcher hex editor To get started 1. Unpack 2. Plug j2534 interface adapter, or op13 or same.. 3. Select DMA proto 4. Press start button 5. Select map manager tab 6. Check checkbox desire map,, or check all 7. Tune your maps (use keysequence zoomin, zoomout, ctrlc, ctrlv) 8. Also can digital log wideband via any serial port or tactrix op20 https://cimg9.ibsrv.net/gimg/www.evo...30e88593e9.png https://cimg2.ibsrv.net/gimg/www.evo...7df77492b3.png https://cimg8.ibsrv.net/gimg/www.evo...be1dc9c9be.png |
now xp dont support if you need xp, rebuild with Qt 5.1. |
added tracer
Hi. Do you have any screenshots of your live map application?
https://www.facebook.com/groups/333122900083948/ prealfa video in group
you download a file and easier to poke debug
some memory leak fix
Add source in first post |
need test 90550001 livemap
update for for stock DMA
Originally Posted by Dow Jhob
(Post 11941692)
Can i use this with my Open Port 2.0 on rom 96260709? Thank you |
Originally Posted by aqeelrizni
(Post 11943166)
Hello Dow Jhob
Can i use this with my Open Port 2.0 on rom 96260709? Thank you after the new year, maybe there will be time |
96262709 Live Map tuning working on Open Port 2.0
Anyone reading this live tuning can be done on the Tactrix Open Port 2.0 thanks to DowJhob
The awesome work by Dow Jhob in driving deep into the code and helping to patch the live tuning to the 96262709 ROM (Ofc building on jcsbanks and ziad incredible work in the past) Been beta testing it with Dow and Successfully managed to get the live tracer working on the fuel, Ignition timing, WGDC and BDEL tables. It is not yet perfect but he is working on it. Anyone interested in testing reach out to him |
(Post 11946898)
Originally Posted by 240Z TwinTurbo
(Post 11946941)
Interested in live mapping the VE table for the 88592715 ROM. Do you have some high level instructions for how this is implemented? I peaked around the site in the original post, but was not clear on how to implement.
the easiest way is to take tephra from dma and display the desired table if it is already part of the altmap, more difficult if not but first, see if your map is included in altmap |
