Evoscan reading zero- ECU ID0000
Hopefully some of you Evoscan guru's can help me out.
I'm running into an issue with evoscan not reading the ecu correctly. When I go to start a log, all of the variable values are zero or "x" in each function, is being read as zero. I have done multiple fresh installs of Evoscan and the drivers, yet nothing seems to help. I am not sure if this is a compatibility issue or what.:confused: I am no expert by any means with evoscan, so please guide me in the right direction if I am out of place.:lol: Attached pic shows exactly how evoscan looks when I try to log: https://cimg0.ibsrv.net/gimg/www.evo...136a1863eb.png The tactrix cable is new and fine; it can pull the rom in ecu flash with no problems. My computer: Windows 10 64 bit Two generic USB hubs One AMD USB 3.0 hub Still get the same issue no matter what port is used. Thanks in advance |
BUMP
I wanna get some logging done |
Bump.. Nobody knows how to fix this?
Has to be some sort of scaling issues. Look how coolant temp is 300+ degrees.
Originally Posted by 4b11slayer
(Post 11760059)
Any help is appreciated though! |
what cable is it? your hooked up to both plugs?
Tactrix 1.3u cable. This is a relatively new cable.
Both are plugs plugged in, ecu flash works fine, I can trigger any actuator in evoscan... Just no logging :confused: |
I'm not near my laptop to see Evoscan but maybe try selecting a different ECU in the drop down list.
