99650115
Has anyone come across Rom ID 99650115 from an Evo 7 ECU. Currently have this rom that has been tuned but I can't seem to find a .xml definition file to read and edit. Any help would be appreciated.
Evo7 GTA ecu?
It's an Evo 7 ECU that has been used in an Evo 6! That's about all I know unfortunately!
I wouldnt worry about the rom -
You can switch to 90550001 which is also a e7 rom. |
Originally Posted by mines5
(Post 11752053)
yhpm
I think that is one of the Ralliart RS roms.
Suggest you get a decent 98640014 xml and change it to open the rom you have and see if most of the relevant maps open correctly. Most Evo7 rom seem to be derived from 98640014. Note, the axis may well be different, but the maps will probably mostly read ok at least as far into the rom as the spark maps. |
Originally Posted by merlin.oz
(Post 11753945)
Suggest you get a decent 98640014 xml and change it to open the rom you have and see if most of the relevant maps open correctly. Most Evo7 rome seem to be derived from 98640014. |
