New build Tephra V7, SD, No Start/Spark
1 Attachment(s)
Ok so i tried posting in the tephra v7 thread but havent had any luck with a reply.
I have a thread up HERE in the Engine/Turbo section trying to diagnosis a no start. So if you take a look in that thread we have covered a lot of the bases. I really think its my work in the ROM that might be holding us back but I don't have anyone around to back me up other than the community here. I believe i did most of all the work if someone can just take a look over my ROM and make sure its set up right. Again have to run Speed Density. Have GM IAT sensor wired in to MAF and Omni 4 Bar MAP Sensor. |
Ok so been going through everything and I re set up ecu to run GM IAT sensor on mat input and the 4 bar omni map sensor scaled right and scaling changed in ecuflash.
updated new rom. |
Is there also anyway someone could hook me up with a updated DataSettings Folder for Evoscan v2.9 ?
Trying to update the xml but doesn't seem like Im getting the new stuff in Evoscan. Havent been able to connect to car either. |
2 Attachment(s)
log of my car cranking over. anyone see anything that sticks out ?
Likely an immobilizer issue.
Either wrong code Ot wrong year selected. Use the dtc scan option in evoscan. If its imobbilizer related usually theres a trouble code that sets. |
yeah i checked dtcs with evoscan about an hr ago. no issues at all. immobilizer is disabled and set for 0004 in the immo section
The car would still start with a bad map sensor or iat sensor. Even if the option was incorrect in the rom.
So you have no spark? How about fuel? Have you used a noid light on the injectors?
Have you checked mechanical timing?
Also your sure the crank sensor wheel is on correct? |
Step 1. Check pin #1 of ignition coils. Should be white red stripe.
Crank plate is on right. indent facing in. new crank sensor.
cam reluctor wheel is in right positon. New cam sensor. Timing is spot on. We have 12v power right to the coils and good ground. have continuity to ecu as well. |
What pin has voltage?
Pin 1 is 12 volts constant ignition on and pin 3 is ecm voltage signal. Pin 2 is ground.
Yeah I had 12v power key on at pin 1
Had good ground at pin 3 and not getting signal from ecu for spark obviously so just tested continuity which is good. |
