-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Changing ECUflash Default COM/USB port (https://www.evolutionm.net/forums/ecu-flash/745378-changing-ecuflash-default-com-usb-port.html)
Pal215 Dec 11, 2017 11:51 AM
Hi Gents,
I apologize if this has been answered, but I searched and could not find any info on this.
I seem to be having a tough time with ECU flash when both my wideband rs232 usb cable and tactrix cable are plugged in. The software defaults to using the rs232 cable unless I unplug it, which of course causes a "fail to read from ECU" message. I checked under the "Flashing" setting in the options, but the menu is blank. Is there an .ini/setup file that could be adjusted to make ECU flash uses the proper USB port?
The version is: 1.44.4341
https://cimg0.ibsrv.net/gimg/www.evo...e2f4e4cf8c.png
Thanks for your help. :mitsu:
Pal215 Dec 12, 2017 11:57 AM
Any insight on this gents? i'm seconds away from installing a USB switch as a bandaid fix.
