Evo 8 stutters and goes lean above 20 psi.All of a sudden.
Whats up guys. So all of a sudden my car started acting up on WOT.
Fp red E85 All supporting mods. Car went from running great to now when i do wot pulls as soon as i hit 20 psi or so you feel either a studder or misfire. And wideband spikes lean. Any thoughts? Do the evo 8s have fuel pressure relay issue like x? If it was a lack of fuel pressure lets say. I dont think it would stutter. Any thoughts? |
Have you logged this?
Yes did a log this morning. I don't see anything that catches my attention in the log.
It all started with my check engine light coming on. For fuel trim code. I had -11.9 fuel trim so I adjusted accordingly. Trims are with in 5 % now and chek engine lamp off. Still didn't fix issue. Im beginning to think this is a outside influence such as coils or wires. I swapped out my plugs also. They weren't brand new but good known units. I just don't understand if its a misfire or a fuel cut or boost cut. |
NOTES:
This vehicle is on speed density Running a OMNI 4 bar and running on fuel temp. Omni has been replaced with good known unit. Exhaust cam position sensor has been swapped with good known unit. |
How's the fuel pressure?
Originally Posted by Evo9_Dubai
(Post 11799019)
Also I can take the car to 6500 rpm part throttle |
The condition is pretty violent.
I don't think its a misfire but I may be wrong. Feels like I hit a brick wall. |
Coil ohm testing
Short SPARK CABLE- 2.794 kOHM Long SPARK CABLE- 5.66 kOHM Coil Boot 1.7 OHM Coil Boot 2 1.0 OHM Coil 1 10.3 kOHM Coil 2 9.86 kOHM |
check to make sure your oem hanger assembly internal filter isn't clogged? When mine clogged it was almost the exact same symptoms. new hanger assembly fixed it all.
Originally Posted by razorlab
(Post 11799038)
Thanks. Any other thoughts razorlab? How can I identify boost or fuel cut? Through a log? Would I see injector duty suddenly get cut? Cause my IDC seems normal. Also If it is boost cut I would see WGDC get cut? |
I just want be clear that this just happened from 1 day to the next.
Went out for a cruise with the boys and felt it on a wot pull. Hour later mil set for fuel trims. Adjusted fuel latency accordingly and fixed the trims. Problem still there. Maybe coincidence. What other sensors might cause this? |
UPDATE: Checked fuel pump assembly for proper pump fitment and also inspected pick up screen. Dirty but not clogged. Cleaned with brake cleaner and air.
Any other thoughts? Im going to Close the spark plug gap down to .020 see if it helps. Currently running 0.21-0.22 |
Also checked hobbs switch operating normal
Is this 91 or e85? If your trims are pulling fuel like you said that would make me think blend change on e85. -11 is pulling alot of fuel, where you able to verify if the ecu was hitting stoich when it was pulling that much fuel? If you change your scaling back to the way it was before compensating for the trims, clear them out by pulling the battery and then testing, does the problem persist?
Yes e85 here in socal.
So just did a pull in 2nd the break up is less violent now with the plug gap set to 0.19. So maybe my coils are tired? |
