Hitting Boost Cut On MBC
So I am currently using a Hallman Pro RX Manual Boost Controller, and I am hitting boost cut everytime I exceed something around 320 load
This is what my boost limit table looks like. Why are these values in percentage, is there anyway I can change them to load? Note: My car has only a MAF sensor and no MAP sensor https://cimg4.ibsrv.net/gimg/www.evo...e314f30201.jpg |
Check your IDC.....it'll be too high.
Tariq... if you have not played around with your maf scaling then 320 load is well over 2 bar the values you see there are load values... 230 translates to something like 1.3 or 1.4 bar... thats why why you are hitting boost cut... |
Originally Posted by 400s
(Post 11807296)
Tariq... if you have not played around with your maf scaling then 320 load is well over 2 bar the values you see there are load values... 230 translates to something like 1.3 or 1.4 bar... thats why why you are hitting boost cut... Also, if those are load values, how come I am hitting the cut at 320 rather than 230? |
Originally Posted by RightSaid fred
(Post 11807240)
Update
This 320 load where it hits boost cut is 23psi on the boost gauge |
Originally Posted by TariqEvo
(Post 11807306)
How do I know for sure it is high? You'll see it on a data log. |
