Knock with Tephra V7 launch maps
Hey eveyone,
So i have to launch maps that I use, both are getting knock. Would it be possible for anyone to help? Thanks! Sorry for my noobness, everyone has to start learning somewhere! |
Oops double posted Admin delete plz
Post up ur launch maps that would help....
Originally Posted by ant_turbo
(Post 11815851)
https://cimg6.ibsrv.net/gimg/www.evo...653a254b8f.jpg l |
Bump
so I tried this again, and tuning and getting lower knock but still something to worry about because after coming off the launch map/2 step, the car kinda sounds like it's running on 3 cylinders and wants to stall.. Then like a few moments later everything is normal again.. Can someone help so I don't blow my motor! Thanks! |
What size turbo are you running?? and fuel
Originally Posted by 4G63_Crazy
(Post 11816248)
Bump
(Post 11816263)
How much psi u hitting?? and what air fuel?? have a wideband??
(Post 11816265)
stock injectors and 8.5 turbo.. Going to be upgrading to an fp green soon
(Post 11816271)
You should defiantly get a wideband ,, you shouldn't mess with any tuning with out it,,,
Reduce some of you timing numbers in the -10,-8 -9 lower them... and then see... if still knocks play with the fuel Its a trial and error ,,, you have mess around with it til u find the sweet spot for ur car
(Post 11816276)
Don't have a Wideband, but I think I'm pushing 10 psi or so..
