cant change scaling for BDEPSI over to omni 4 bar on 9653 Rom
Hi, my 9653 rom using psi based boost control is set for jdm 3 bar but i have the omni 4 bar if i edit the scaling in ecu flash and apply it and save. I close the program and re open it then load the rom and open the scalings its gone back to the jdm map sensor.. anyone else had this problem? I belive it also the reason my boost error is reading -3 constantly when logging. Thanks for any advice in advance. |
You have to change it from the xml. Attach your xml here and I'll change it for you
