Afr going richer gear by gear
1 Attachment(s)
i everybody, i have an very strange problem with my tune.
when i do a pull in 2. gear it goes about 12,5 then i flatshift to 3.gear it goes 11.5 then 4. 10,5 i'm aiming for what it does in third gear 11,5-11,8 ish what the hell is going on here :P is this a simple noob error ? i have attached the log 9:1 compression ams intake stock turbo and injectors. (and yes i know the injectors is maxed out new is on the way) https://cimg1.ibsrv.net/gimg/www.evo...3d5def711c.png |
Turn off lean spool
is turned off :(
*edit* i think it is, its set to 8000rpm enable or is it necessary to find the bit that disables it ? |
Originally Posted by Michael Jensen
(Post 11842486)
is turned off :(
*edit* i think it is, its set to 8000rpm enable or is it necessary to find the bit that disables it ? However know you will have to retune your fuel table once you disable lean spool |
Ok thank you didnt know there were over time modifier also.
i'm running tephramod with rom 88580714 i have found under ecu periphery1 FBA bits bit 0: lean spool, is it just this bit i have to set to zero ? |
(Post 11842488)
i'm running tephramod with rom 88580714 i have found under ecu periphery1 FBA bits bit 0: lean spool, is it just this bit i have to set to zero ? The table I was eluding to is this one: https://www.evolutionm.net/forums/at..._leanspool.png This is after someone changed the values to match. OEM they are richer. Which causes the effect you are seeing. |
Originally Posted by razorlab
(Post 11842498)
yes turn the bit off.
