Help can not connect to ECU
i had a break in tune on the car and I pulled the tune just fine using ECUFLash. I had a lot of issues trying to re-upload a new file. Now I can’t connect to the ECU at all evo when I use a code reader it states no link. I checked all my connections and checked the fuses. My tunner thinks that it is the ECU but I don’t understand why it would just die. I also have the battery hooked up to another car thinking it was low on power. I am out of options please help!! https://cimg1.ibsrv.net/gimg/www.evo...14aac8771.jpeg |
check the obd connector in the car, maybe a pin got pushed out.
I checked all the pins everything seems solid |
Originally Posted by Mmarlow123
(Post 11864775)
Is that easy to do for someone who does not know crap about it? |
My IX will say that sometimes if my mini battery gets a little low. I'll idle the car for a min then hold it at 3k for 10 - 15 seconds then go key on engine off immediately & hit flash.
I know you mentioned you put another battery on but i had this problem once and i had to attach a portable battery charger to my battery and then connect to my ECU.
The car will not start to run and I tried hooking up another car and the battery charger. |
I’m literally lost at this point I just put a brand new battery in it still nothing I checked all the fuses still nothing I checked all the pens still nothing do I have to buy a new ECU at this point.I’ve dump so much money in this car if I buy a used ECU can I flash it to this car |
(Post 11864778)
Also, check the #8 20A fuse in your engine bay listed as "Engine Control" in your manual. If that fuse is blown the engine wont run or connect to ecuflash.
Since nobody has mentioned it, do you have the little mitsubishi adapter plug connected properly?
You need it to be able to flash the ECU. |
Yep checked #8 fuse and changed it just for good measure and yes the apapter is connected when I try to flash it. It is as if the ECU just took a crap!! is this common? If I get a used ecu am I able to flash it to the car? |
Are you able to connect to evoscan?
Also, I've notice that if I have another USB device plugged into my laptop while trying to connect to ecuflash it doesn't work. I need to unplug all USB connections except the 1.3U cable inorder to read/write to the ecu. |
I had the same issue you are describing and it ended up being my 1.3u cable. See if you can trade with a friend and verify that is not the case. It is rare for the ECU itself to fail.
