p0462-88590715
Just installed walbro 255 -
flashed 88590715 . Getting the code p0462 - Does any one know which periphery bit to disable the code ? Does it indicate a faulty fuel level sensor or the fuel pump hanger from any other model ? at the same time i am getting a miss fire while i enter boost with full throttle. If i take it gradually it doesnt do it . P0462 is turning out to be a pain in the a** !!! |
Update*
"at the same time i am getting a miss fire while i enter boost with full throttle. If i take it gradually it doesnt do it ." This has been solved. P0462 remains.. Any one ? |
Try Periphery 3 (FDA) bit 11
Originally Posted by cdrinkh2o
(Post 11865704)
https://www.evolutionm.net/forums/ev...low-input.html
Also, the thread below shows some code that can be added....Post #13 has a link and Post #21 shows the code that can be added. https://www.evolutionm.net/forums/ec...n-t-clear.html |
