-   European Forum (https://www.evolutionm.net/forums/european-forum-49/)
-   -   Evo 6 ECU's Boost pressure (https://www.evolutionm.net/forums/european-forum/17941-evo-6-ecus-boost-pressure.html)
mitsimart Mar 27, 2003 06:28 AM
Have just fiited a Rallyart ECU (Rally) ,cant feel any significant improvement in the performance,maybe slight decrease in lag. do you have to manually increase and set boost pressure or should that be done electronically. Ralliart part No for ECU is RA420996R1
Claudius Apr 21, 2003 06:07 AM
You should replace the restrictor to the WG to increase boost, or buy a boost controller. This ECU is programmed to work with 1.3 bars boost.
RENN-ART Feb 5, 2004 05:03 PM
what claudius said..
first i suggest u get a boost gauge installed to check what's going on..
then get a boost controller to get the steadiest boost.. which can be had very cheap, by the way..
NotNormal Nov 15, 2004 03:09 PM
I run 1.55 bar of boost with a Blitz SBC-iD3 boost controller + uprated fuel pump .
The fueling's spot-on on stck injector ect.....
For "spirited" driving i find that 1.4 bar is just right in term's of spool up drivability.
Tom
siggo Apr 20, 2005 05:52 AM
Claudius,
I have an Australian delivered 6.5 TME, and have looked for the restrictor shown in the service manual (at the turbo end of the Tee piece), but can't find one.
Do you mean to put in a restrictor?
Would appreciate more details please. (hole size and location etc)
I can't get mine to go over 15 PSI even with the boost control solenoid open 100%
Cheers
