english racing tuned 407hp pump gas magic...
Despite many tuners claims of stock ecu only being good to 375hp and 25psi, here is the graph and mods to proof otherwise.
Mods are:
Stock 2L bottom end
FP Green
Garage HRS exhaust mani
EPM 02 dump- spits hot fire!!not kidding....
Tanabe Downpipe
ETS 3.5" downpipe back exhaust
GSC S1 cams
ETS LICP
Fujita UICP and intake
Hallman MBC
FIC 780's
Walbro 255
Magnus SheetMetal street intake mani
Car is daily driven 70 miles and has 57k on the bottom end.
Mods are:
Stock 2L bottom end
FP Green
Tanabe Downpipe
GSC S1 cams
ETS LICP
Hallman MBC
FIC 780's
Walbro 255
??? you lost me. who claimed a stock ecu is good to 375 and 25psi?? there are lots of stock ecu cars that make over 400 to the tires. you also have a green, SMI, etc
and i believe mellon has blown any and every stock number away as of recent, so i fail to understand what your saying.
ninja edit:
not trying to take anything away from your car, i just do not understand what you are saying
ninja edit:
ninja edit:
ninja edit:
There has been a few shops out there that have claimed that the stock ecu is useless at power levels over 375.
You have to admit that damn near 30psi and 400hp is impressive.
1 Post
see the vid in my sig... 93 octane 34.5psi peak through the stock ecu/mas...you've just scratched the surface *video*
what your car is doing is good but it's been done many times, that's all.
I don't know of any tuner on EVOm that's going to make a claim like that...maybe a local tuner told you that?
Its a tribute to a persistent approach to keep dialing in the tune. As mellon has done with all of his setups. Once you travel that path you should be able to replicate it easier and possibly push it farther
Very nice numbers on the setup by the way. 30 psi all day on pump is fun no matter what size turbo you are doing it with
We run quite a few cars at 30+psi on E85 but the main problem with a small turbo and high boost on 92 has been the timing has been so low typically that the best you can get is high EGTs with 9* out the top. We got 13* out the top with this setup this time around, the manifold didnt glow in the dark (literally tested it).
This car can make a pull in 5th and accelerate clean with no knock. The bigger the turbo the easier it is to replicate because at a given boost level the charge temp is already greatly reduced compared to a little turbo. We heat soaked the heck out of the 3.5" TurboXS intercooler and didnt have any problems.
It might seem like a minor accomplishment to some, but I dont see too many people on stock/stock appearing turbos (other than Razorlab and myself) having succeeded in doing this on lower octane premium. I actually have run more but couldnt get it too stay consistent @ 34-35psi spikes with the Green.
