question on tuning please help.
im doing these mods: invidia DP, TP, o2 housing w/ injen uicp licp + intake kit and boost controller...do i need injectors and a fuel pump? should i be fine during the summer since im raising the boost?
definitely get a fuel pump! saftey first... Injectors, if you dont have an exhaust you should be fine... I have same mods minus the 02, but I have an exhaust, and Im hitting 0ver 100% IDC @ 7000 (ECU controlled boost) just noticed your gonna be using a MBC. I believe you would require less IDC w/ a MBC. but, if your wallet permits, you might wanna get injectors as well. Kinda wish I would have gotten injectors, when I had the $$$.
yeah im not even sure what to do because i was told a fuel pump is pointless without injectors and i dont really want to spend $400 on injectors i will only be running around 23psi
You can get injectors cheaper than $400....it all depends on your IJDC....you have an Evo9 whic doesn't require an upgraded pump for modest mods, now Evo8's should always get an upgraded Walbro255.
Go into some more detail, have you been tuned, etc...cause by adding all thos mods at one time you will need a tune fo-sho...a walbro is less than $100, might be good insurance when you do get a tune, the tuner will have a little room to play with.
You can get injectors cheaper than $400....it all depends on your IJDC....you have an Evo9 which doesn't require an upgraded pump for modest mods, now Evo8's should always get an upgraded Walbro255.
Go into some more detail, have you been tuned, etc...cause by adding all those mods at one time you will need a tune for-shure...a walbro is less than $100, might be good insurance when you do get a tune, the tuner will have a little more room to play with.
no i havent been tuned yet im putting all of these mods on at the tuning place and getting tuned right there but i was told if i wasnt getting injectors a fuel pump wouldnt do anything but i dont think that is true at all (the tuner didnt tell me that a few friends did)
EVIL_EVO_VIII
127
Feb 27, 2007 05:34 PM
