03VIII FP Green 416 awhp & 382 tq Thanks to Mojo Motorsport
Today was a long day for me and Adam @ Mojo Motorsport in Amityville Longisland. Started at 10.30 am and ended at 7 pm tunning the car. We first started scaling the injectors and getting the fuel trims right . took us about 3 hours to get everything right and get the trims were we wanted them to be. Also adjusted the idle for cams and got them running smooth at idle. then we head on road course to tune the car. after couple of 3 gear pulls and adjusting the maps accordingly, i was making a decent amount of hp and tq and car was blast to drive. But i wasn't looking for those number i want to reach the limits of the green on 93 octane. It was pretty late in the day and i was hungry and so was Adam, plus i was tired of sitting in my car for 5 hours. so got some food for our self's and headed back for more tweaking. couple of more 3 gear pulls and few tweaks we had the green making more power then Adam expected it to make on 93 octane. our final number for 3 gear pull was 416 hp and 382 tq avg. and 4 gear pull was avg 440 hp & 392 tq. I want to thanks Adam for been so helpful and patience with me. Adam explained me everything as he was tweaking the map and answered all my question . Mojo Motorsport Highly recommended to all Longisland residents.
26.5 psi
Here is Dyno pull. This was done at DG Motors on their DYNODYNAMICS . Thank you DG Motors for letting us use their Dyno.
Mods
stock bottom end
stock head with Kelford 272, BC springs and retainers
SparkTech Non-CDI Cop Ignition
Arp Studs
Stock intake Manifold and TB
FIC 850 , walbaro 255
FP Green with Forge Wastegate Actuator , Ported Exhaust Manifold, EPM O2 Dump. 3inch straight turbo back Exhaust.
ETS 3.5 IC, Muse LICP, buschur ucip with Forge bypass Valve, Hks intake pipe with Vibrant Filter , hallman MBC
ACT Street lite Flywheel with ACT MB7-HDG6 clutch
everything else is stock...
26.5 psi
Mods
stock bottom end
Arp Studs
Sweet numbers man. Yes Adam is the man. I was there sunday and yesterday, but then again I feel like I'm always there lol. Great guy, and he definately knows his stuff .
The car surprised me a little, in a good way. We were in the high threes power wise and Aman wanted to try adding in timing that I was pretty sure was going to cause knock but it didn't. I think we finished with 11 or 12 degrees toward redline.
Aman obviously did a great job of putting the car together including his own port work on the exhaust manifold. The boost levels and power output on pump gas has increased so much in the past year or so, it's very cool. I think we are now at the limit but who knows.
Thank you for the positive review. -Adam
I have simular numbers with simular mods. I found that if you raise the lean spool stop to be just a tad less than your rev limit, the car will hold a bit more power to the rev limit and not fall like crazy at 6500.
You can have the lean spool off at 1000rpm and if the turbo can't keep up and you don't have the octane to supplement timing with boost dropping, the power will taper.
On two separate Evo's when I turned off lean spool the cars bogged rich in high gear, low rpm, full throttle. Based upon that my belief is that all lean spool does is keep the car from bogging rich in the transition from cruising load to full boost (hence the name "lean spool") and not much more because once you get into the WOT fuel tables you can set whatever a/f ratio you want.
This thread has not gone there yet but I ask that we keep it civil, I don't know, I just have a feeling. -Adam
WOW.....Sorry I didn't intend to step on anyones peepee.
I am simply stating that lean spool clips at 7k. Due to ECU interpolation it can cause a loss of power when the lean spool shuts off. This can happen anywhere between 6200 and 7000 rpm. By changing the "lean spool stop value to just a tad under redline, there isn't a loss in power when it shuts off.
I was simply offereing advice to someone with mods simular to mine. People on this site are so sensitive.
Also, just so I am straight here, I have been wondering this for a while. When I look at an Evo 8 map in Ecuflash it says "Boost Enhancement (anti-lag)" which starts at 2500rpm and shuts off at 4500rpm. Nothing anywhere about lean spool. Looking at a 9 rom I see lean spool start at 2500 and stop at 7000. Is there no lean spool on an Evo 8 or is anti lag and lean spool the same thing? -Adam
