590whp 576wtq@40.2psi FPred/Stock Block (TTP TUNED)
Old Oct 12, 2009, 11:09 AM
  #256
norcalSRTrida's Avatar
Originally Posted by Migsubishi
My friend, the added money is there from the start... ACT $440 ~ PTT $1200
There is definitely more to replace, two friction surfaces and two discs, then whatever the main cover needs and of course the flywheel.
makes sense. just didnt expect a 'rebuild' to be so much different from a single disc.
Luckily I got a QM TD w/ 1k miles on it for $600 in perfectly good condition. hopefully i wont be needing a rebuild anytime soon.
thanks for the headsup.
Old Oct 12, 2009, 11:15 AM
  #257
Originally Posted by SPEC-01
In most instances a rebuild for our Super-Twin will cost about 50% of the initial purchase price. And as mentioned rebuilds are more costly and more involved than simply replacing a disc or discs for that matter. You also have to replace the floater and pressure-plate surface as well as resurface the flywheel (cutting steel flywheels and replacing the FPK on Aluminum ones. This requires the unit to come back to us but the rebuild time is less than 48-hrs in most instances. Every company is different and the above info is relative to our kits only. Let me know if you have any further questions. Thanks,
you should get some revised test units of a lighter assembly on some cars making power and going to the track often and see if the revised unit(s) diminishes the complaints about gear lockout/shift problems at high rpm.
The Cust. Service is there...just should touch up on the product some, and then the consumers will have a complete package..
just me .02
Old Oct 12, 2009, 12:54 PM
  #258
SPEC-01's Avatar
Since this issue is found on a limited number of units (3 now is my count) this truly isn't widespread. I have one of these units coming back for further assessment and testing (E85's clutch). I just spoke with Mike and I am sure that he will keep you all up to date on things and I will do this as well. Let me know if you have any further questions. Thanks and have a good afternoon!
Old Oct 12, 2009, 07:54 PM
  #259
MR.06MR's Avatar
Is 40psi bad on a stock block? also does it still run perfect?
Old Oct 12, 2009, 08:00 PM
  #260
RyuEvoIX's Avatar
Apparently it is still in the realm of possible and the car runs flawlessly. It is my daily driver at 37psi.
Old May 14, 2010, 10:00 AM
  #261
EvoPower81's Avatar
How many jets of aquamist do you run?
Old May 15, 2010, 06:42 PM
  #262
suprafabs's Avatar
and i was worried about boosting 28psi on stock motor....lol wow congrats.... goodluck
Old May 15, 2010, 08:51 PM
  #263
9SECndEVO's Avatar
40+ psi? WOW
Old May 16, 2010, 06:41 AM
  #264
CMB
CMB's Avatar
How the hell do you get that much boost out of the red? People with the Black have trouble going past 37psi
RyuEvoIX
Mar 27, 2012 12:47 PM
RyuEvoIX
Jul 12, 2009 03:57 AM
RyuEvoIX
Apr 17, 2009 07:16 PM
RyuEvoIX
Mar 30, 2009 11:17 AM
RyuEvoIX
Jan 27, 2009 12:21 PM
Quick Reply: 590whp 576wtq@40.2psi FPred/Stock Block (TTP TUNED)
