Red vs Black on Pump
Old Dec 8, 2009 | 01:28 AM
  #91
yahu's Avatar
^why won't you reply to threads on a Sunday! And it isn't like you have a pile of work to get to on Mondays, or customer cars to look at all weekend! </dripping with sarcasm>
Calm down a bit, Mirage Aaron was busy helping me out on his "day off"
Back to this thread (kind of): Aaron - I got a head's up on good 4-day shipped pricing on S2s. Did you already put me in for a set? If so, nevermind.
Old Dec 8, 2009 | 09:17 AM
  #92
JohnBradley's Avatar
I like to keep them on hand, no worries
Old Dec 8, 2009 | 03:49 PM
  #93
BLKCarbonEVO's Avatar
Dan, we need to see a full 100% meth tune! I think the S2s will work wonders in your car but they will also give you a good amount of tq too...
Mikey
Old Dec 8, 2009 | 04:25 PM
  #94
yahu's Avatar
^you back Mikey?
I haven't ordered them, Aaron, so I'll ping you.
Old Dec 8, 2009 | 05:07 PM
  #95
miragevo's Avatar
Veteran: Navy
Originally Posted by JohnBradley
Nope they are the latest version but not the version that was in the Red car that was posted apparently. Centerline changes and obviously the overall duration of the intake cam have been altered. I went back through my engine simulation where I also keep track of everyones motors that we have personally built and compare my sim to real life.
It quite clearly lists the lift much as Greg had posted at 11.2/11. I think him and I had talked about an S2 that might have had an S3 in the woodpile and this is where I got confused. To be clear I was holding off on responding if in fact I had totally barked up a wrong tree. Greg clarified the point for us before I could respond.
Thanks Aaron, for the explanation.
Old Dec 9, 2009 | 11:43 AM
  #96
you back Mikey?
Dan, no I'm still overseas. I just happen to have computer access. I come home next Thursday, I think...
From looking at your previous Red Graph and this Black graph, It looks like the Black makes 20-25 more horsepower at the same tq level.
Once Eric and I get my car modded if my tq is still above 400, like it is now, I may not go Black. I would however be okay on 575/425 on the Black but I don't want to break anything.
Also I see that you are getting the S2s. Your tq will prob go up 20+ on those cams. They like to make a lot more tq then the Mseries cams. However, making another 30-40hp would be pretty sweet.
Mikey
Old Dec 9, 2009 | 11:59 AM
  #97
EVO8LTW's Avatar
^If you want less torque down low, just run electronic boost control.
Old Dec 9, 2009 | 12:51 PM
  #98
lan_evo_mr9's Avatar
JB, what type of fueling supply would be required for a black on E85? Is a double pumper necessary or could the ID2K's work with a AdjFPR? I don't want to get crazy with my fueling system but definitely want to be very safe.
Old Dec 9, 2009 | 01:33 PM
  #99
You will definitely need a big pump setup if you are looking to max out the Black on E85. Luke is using 2 Bosch 040 inlines (slightly smaller than the 044) rigged in parallel and -6 lines to a -8 feed w/ AFPR. On top of that its feeding FIC2150s to make sure we have the fuel for the power.
Old Dec 9, 2009 | 05:28 PM
  #100
yahu's Avatar
Mikey
Still getting back in time for the kiddo or not anymore?
I'm not jumping on the S2s yet (Jaybles needs to reply to my email! haha) but will right after the new year probably. Gotta figure out another excuse to get down to Vancouver.
Old Dec 9, 2009 | 05:45 PM
  #101
^ Hey I need to take my car down once I get back. I'll go with you if you want. I wont be able to go till the first week in Jan... lmk
Mikey
Old Dec 9, 2009 | 08:26 PM
  #102
BenJ's Avatar
So correct me if I'm wrong, but I'm fairly confident that your name is Aaron, but I have been calling you John. Is this correct? Sorry for the OT but to bring it back, any reason for running two inlines vs twin in tanks?
Old Dec 10, 2009 | 08:48 AM
  #103
Johnbradley- https://www.evolutionm.net/forums/no...hnbradley.html
255 Inlines flow a little more because they dont have as much pressure drop, the pumps I am talking about are even larger. If you have modded 255 in-tanks its about the same. The other reason I lile inlines is 2 in-tanks and all the fittings makes it awful crowded when you need to work on the pumps.
Old Dec 10, 2009 | 12:06 PM
  #104
460hpevo8's Avatar
to the op, with all the hype the fp black got. 30-35hp different from the red is not that much.
Old Dec 10, 2009 | 12:29 PM
  #105
BenJ's Avatar
the Black outperforms the red in every aspect. Full boost at 3800 on a stock 2.0l and 600whp+ possible on a mustang or 700+ on a dynojet is pretty impressive. I'm running the FP black on 29psi, tapering to 27 at redline with a very conservative tune on E85 and i'm putting down 450/390 on a mustang all day long. At higher boost and a less conservative tune, this turbo will $h!t all over the red even more. /thread.
