FP Black- Cosworth M2 - Aquamist HFS-6 (50/50) - 850cc FIC - Stock Block -Long Winded
After six month of countless logs and roms, taxtrix cable failures and a blown turbo from inadequate oil choice, hours and hours hours of reading and cursing, I'm happy with my tune. The car makes as much peak hp now with about 4psi less than it did on the FP Red when it was tuned by a professional tuner, albeit with about 30 less tq and a loss of about 300rpm spool. EDIT: AND that was on a physical dynojet!! So not the same dyno.
Numbers: ~500whp/430tq. 33psi. Virtual Dyno, 1.09 Default DynoJet Factor.
Disclaimer:
1. My setup likes boost. For whatever reason, timing makes it knock, boost does not. Also, I'm 95% sure my knock sensor is overly sensitive Sitting in neutral, the car will register a few counts of knock just by revving it. After months of trying to tune out sub 30%-throttle knock, it just isn't going to happen... Even with that said, I only get between 0 and 1 counts of knock at WOT. Make of that what you will. The car runs smooth as glass and is fast by my standards...
2. I know you and your friend may have made 1,800hp @ 2,500 rpm with 8psi, but guess what, I can't. Be it my tuning or my setup, i just can't make it happen no matter how hard i try. Good for you.... Maybe it's because this was a budget build except for where it counts? Who knows, i don't.
3. The car loves being at 12afr. It makes a lot more power there then it does where I have it now. Why don't i put it there? Because I'm afraid and I daily drive this thing. You think 12afr doesn't' make a lot more power than where I'm at?? Good for you. My particular setup likes it there a lot.
4. I will report back the moment the tracks open with trap speeds. I'm currently on a stock 6 speed and wont be gunning for any ET's until i get something beefier in there. I will turn the boost up a few psi at that point as well. It should land the AFR's right in that sweet spot. It will only be for a pass or two.
5. This pull is 100% legit. 100% flat/smooth ground, and I was VERY stingy with the weight. I still even have the OE jack and spare. I could realistically add another 40lbs if you include the car parts in the trunk and other various things in the back seat lol. Done in third gear with over a 1/2 tank of gas... for what it's worth. Also I have many many graphs like these that look very similar.
FP Black
FP 18psi Wastegate
FP Intake Pipe
Forge RS BOV
Cosworth M2 Cams
ETS 3inch FMIC
ETS LICP
TurboTrix UICP
Amsoil Cone Filter
Silicone Hoses Cajun Power T-Bolt Clamp Kit
Mil. Spec 65 MM throttle body
Hallman MBC
PPI Ported Intake Manifold
FIC 850cc Injectors
Ported exhaust manifold
Megan o2 house
Megan Turboback
One stage cooler plugs.
Still open to constructive comments/recommendations.
I plan on playing with the tune more. It's VERY tempting to turn the boost back up to the level old tuner had it with the FP Red, but I'll keep my cool until I get a pass or two in. I will be at Island the month they open. Wish me luck.
ohh, and one other things. Playing with MIVEC DOES help spool. I gained about 300rpm by working it hard over and over. But it DID make my car more prone to knock in some areas so I played it cool here too. I couldn't make any note worthy improvements past about 5000rpms thought. Again, that's just ME with MY SETUP.
Disclaimer:
FP Black
FP 18psi Wastegate
FP Intake Pipe
Forge RS BOV
Cosworth M2 Cams
ETS 3inch FMIC
ETS LICP
TurboTrix UICP
Amsoil Cone Filter
Hallman MBC
FIC 850cc Injectors
Megan o2 house
Megan Turboback
That is some good power man.. that tq is kinda high for my taste on the stocker.
If you dont mind... how much timing were you running at peak load and up top? you can PM ME if you like.
nice power man congratulations!! maybe 1 degree less timing and 28 29 psi boost you can run much more safe i dont like this kind of power on a stock block DD but this is my opinion.. this is your car and your choice
Here was the dyno pull from with the original tune on the RED with a lot more boost. BUT, i also just remembered this was on a 100cell cat:
As you can see, the car was making much more TQ with the higher PSI. We turned it down for daily driving though. Obviously this wasn't something i wanted to subject the motor to that often. With that said, if i turned the black up to that PSI, i'm confident I'd destroy those numbers and soon after my trans if not motor. lol
Thanks for everyone's feedback. Peak TQ timing is 4*, but it only hits it briefly. Most of the pull goes from 9 down to 5, briefly 4, and then quickly up to about 14*.
Meth is coming on at 40% injector duty cycle (this is earlier than where it was with the red) by anout 15%, and matching them 50%. It's running the two smaller Jets.
Injectors max in the very low 80's That's one perk about meth, small drivable/tunable injectors lol with good hp.
And yeah, i'm considering turning the boost down more. You can't really help yourself when the power is there to use :-/
I'll likely post my current timing map tonight. It's come a long way lol.
For the correction factor being used, it's not bad. On a uncorrected dynojet, his peak torque would be high 300's. Which should be reliable on the stock motor. From what ive read on this forum, and from experience.
Nice work again on the car... That is a nice pek about meth, small injectors and good power
Good job though carloverx.. just understand if it was knocking in neutral reving then theres more power in the car.
its hard to tune a car with phantom knock.. if you want help removing the false knock pm me. free of course.
really? I was quickly judging spool improvements/losses by where TQ passed 400. Now it typically pass it around 4,750. For an FP black, i thought that was pretty good?? It doesn't look like the small stock frame FP turbos are doing much better? And it's even pretty damn close t my Red.
As for 50whp more, would I get this through adjusting the knock sensor and going more aggressive with the timing? (Not that I'm looking for any more HP though ) Like i mentioned, the car likes boost more than timing for some reason. I'm confident i could turn up the boost and easily make more power. I'm actually tempted to just for a dyno sheet lol. thanks for the feedback.
best thing in your case is to tune with no meth and find where your cars happy on straight pump, then add the meth and adjust accordingly.. and add your timing uptop to take advantage of the meth.
you should see 33psi by atleast 4400rpm max.
ill help you sort out the knock sensor if you want.. but ya, if you have a map sensor you can log boost with, you want to stop tuning for spoolup around 10psi.. in your case. if no boost logging ability then just go by load.
Ohh, i see what you're saying. I need to drop my AFR's earlier?
And the only problem with tuning before and after meth, are those little baby injectors I'm running lol I suspect I'd run out of fuel with them before I had a antiquate map to base the meth map off of ?
I'll keep you posted. I'm tied up at work now but I'll certainly shoot you a pm when I get a chance to play with the knock sensor. Then again, I didn't touch it yet b/c i'm not interested in really making more power on the stock block daily driver I'll give it some thought this weekend lol
