MAP EF-series Turbochargers results thread
#1518
I bought mine used. I can't say how it was treated before I bought it. I also had a faulty DV that wasn't relieving pressure very well. So, I can't say why it died. I've never seen a shaft snap before.
I had it rebuilt. The customer service was awesome, the turn around time was great, and I got a nice upgrade, due to a change in the design.
Now we'll see how it goes.
#1522
4G64/R2s/E85
Finally made the switch to speed density and E85 but the walbro 400 appeared to have the same limits as a walbro 255 with out re-wiring it.. power-wise it feels great but in terms of spool it was really lagging.. granted this is a pretty large stock appearing turbo i knew it was going to be a little on the laggy side but wow...
~Mod List~
4G64 Short Block w/BSE (8:6:1 CR)
Eagle 100mm crank
Manley Rods/Pistons/ .20 bore
GSC R2s
(E85) Walbro 400 fuel Pump
FIC Bluemax 1450cc inj.
M2 performance 3” TBE
Spoolinup COP
Muse O2 dump
Works 65mm TB
Agency Power BOV
STM 3" SD Intake
Hallmen MBC
Nisei Intercooler/LICP/UICP
Stock Intake Manifold
Ported exhaust manifold
Ported MAP EF4 turbo w/ Anti-Serg cover/turbo smart WG
Ran out of Fuel Pump at 29PSI
~Mod List~
Eagle 100mm crank
GSC R2s
Spoolinup COP
Muse O2 dump
Works 65mm TB
Agency Power BOV
STM 3" SD Intake
Hallmen MBC
#1523
#1525
The simplest way to fix the issue is to buy a double pumper..
Another way I've been looking into is a fuel pump rewire with high/low voltage circuit which basically a uses OE concept but in uses another relay with high voltage directly from the battery...(this is my basic understanding and is a lot cheaper)
#1526
~Mod List~
Eagle 100mm crank
GSC R2s
Spoolinup COP
Muse O2 dump
Works 65mm TB
Agency Power BOV
STM 3" SD Intake
Hallmen MBC
~Mod List~
Eagle 100mm crank
GSC R2s
Spoolinup COP
Muse O2 dump
Works 65mm TB
Agency Power BOV
STM 3" SD Intake
Hallmen MBC
#1528
My entire fuel system is stock, unmodified 255, and FIC 1450s on a 2.0 block. I'd have to ask Jay what my duty cycle is....but it's reasonable at 28-30psi on a ef2.5 and I think we're around 479whp or so.
**edit. I did the math..my rule of thumb for injectors is cc/2=whp. If you take that and deduct 30% for e85, that's 500....so I guess that is right. Time for larger injectors, my friend!
#1529
Injectors aren't it either I don't think.
On my 2.2L I maxed out at 630whp or so on E85 with a wally 450 and 1300cc injectors. There are a lot of other restrictions this car has.
I had fuel feed line (6AN), AFPR, boomba fuel rail and I modified my return in my basket to reduce pressure.
Instead of getting new injectors or spending money on a new pump it might make sense to upgrade other parts of your fuel system. Just saying.
