FP HTA Green Stock Block 93 Octane & E85 - Tuned by TSCOMPUSA/VR-Speed
very nice intake box man. i want to do something like that. when the car gets hot and the radiator fan turns on your intake will suck in like 300F+ of hot air on a hot summer day.. definitely not good. your setup is very nice and white is my fav color for evos.
on e85 i will get this car about 500whp - clutch slipped when i added 3 deg more from a already conservative base map so im curious what it maxes out at myself.
and im in the same boat with the clutch thing.. def not fun to drop the transmission.
i like the pic at the track, you look like a man on a mission and focused in.
Dan (drb)
heres an example here of tq control: - kept it low but not so low that it would jeopardize the fun factor of the vehicle while having much higher hp
https://www.evolutionm.net/forums/ev...e85-500hp.html
then here it is on 93oct, youll notice the tq curve much earlier here:
https://www.evolutionm.net/forums/ev...ane-28psi.html
so it just depends..
I try to tune all cars in 3rd gear and if i tune in 4th i will make note on the forum post that way people can compare results with results.
also the above car is mivec, which also can be manipulated to assist in spool. this specific evo in this post is an evo 8 (non mivec).
if you really want to see what the turbos capable of, search for some built evos like Curt Browns on the fp green hta.
but ya your intake box is awesome. maybe you can design me one
around there yes. i can probably make it alittle quicker, but the sooner peak tq occurs the more blow the rods get which isnt something you want on stock rods. the torque is forced to stop increasing as well in early rpm to protect the engine, otherwise this turbo can be a torque monster. i dont remove the tq enough to sacrifice the power curves and flatten the tq curve, but i do it enough to maintain safety.
ok that is good to know thanks so i am running the same intake pipe as you did you have to modify the fp intake pipe or just use a lower profile filter like the hks?
Something similar to the attached picture.
