Borgwarner Twin Scroll 7670 With Dyno Graph
Old Nov 7, 2011 | 10:43 AM
  #436
SmurfZilla's Avatar
Someone mentioned this happened to someone in the UK....can someone confirm. maybe there is a common theme between the 2 incidents.
Old Nov 7, 2011 | 10:45 AM
  #437
leetEVO's Avatar
Originally Posted by project_skyline
I thought these turbos had a 1 year warranty no questions asked. Keep us updated on process, because I aint gonna rock a turbo with no customer support or service.
Will do. Fullrace has excellent customer service. Geoff has hooked me up. There was some mis-communication is all.
I'm sure Borgwarner will stand behind it. From what I was told there hasn't been an issue with exchanges
Old Nov 7, 2011 | 10:48 AM
  #438
leetEVO's Avatar
Originally Posted by n2oiroc
what would cause the shaft to bend besides surge? out of balance? i suppose it would be hard to tell with an anti surge housing, but did it ever feel like it could have surged?
No surge. I have it on my gopro.... back straight full throttle and then metallic whine. No surging or bucking etc....
Old Nov 7, 2011 | 10:57 AM
  #439
n2oiroc's Avatar
weird. im scouring google for causes and a few were surge, over speeding, too much back pressure and thats all i came up with so far. either way, i hope its just an issue with the early ones and that its resolved. keep us updated with how the replacement works, i hope its trouble free.
Old Nov 7, 2011 | 11:33 AM
  #440
evosdad's Avatar
I have a source that uses these turbos and I was told that BW said to really watch shaft speeds, especially if your using this turbo for track events. My source told me if I can run a Speed sensor, RUN a speed sensor, implying its pretty much a must.
Old Nov 7, 2011 | 11:52 AM
  #441
David Buschur's Avatar
The turbo was never over 35 psi here and left at 28 psi, I'd think that is well within the shaft speeds it is suppose to run.
Old Nov 7, 2011 | 11:53 AM
  #442
leetEVO's Avatar
Originally Posted by evosdad;97
27432
Hmmm.. what good will that do? It simply measures the shaft speed right? It's not as though it can actively do something yah?
Meaning.... if it was the cause you could look at the data and say....yep the shaft was spinning 10000000000 times too fast that's what caused the turbo to grenade. I have to imagine you're not going to have much warning? Anyone have insight on this?
Old Nov 7, 2011 | 12:04 PM
  #443
n2oiroc's Avatar
just another parameter to watch and log. say it has a max shaft speed of 150k rpm and you consistantly log 130k rpm. you know you are good. either way, having to run a shaft speed sensor is absurd for anyone but a race team.
Old Nov 7, 2011 | 12:08 PM
  #444
wings1833's Avatar
Couldn't a shaft speed sensor set to open wastegates/reduce boost/whatever so you don't keep it spinning if above X RPM?
Either way, good luck.
Any plans on uploading the GoPro Video? anxious to see it.
Old Nov 7, 2011 | 12:09 PM
  #445
JARVEVO8's Avatar
Ok, so Geoff's Turbo is a "2nd generation" then? right?
If so, got beat the hell out of that Turbo!!! lol
I don't know if it's new or what, but the GTX3576 has me reallyyyyy going!
Old Nov 7, 2011 | 12:10 PM
  #446
evosdad's Avatar
Yeah, it's just something to watch like a WB gauge. If its spinning too fast, reduce boost.
I wasn't emplying it was over spun Dave, just saying since someone mentioned about over spun shafts could bend.
Yeah not very many have the capabilitys to run that sensor.
Old Nov 7, 2011 | 12:20 PM
  #447
leetEVO's Avatar
I'd like to see the gtx3076 vs hta3076
Old Nov 7, 2011 | 12:54 PM
  #448
n2oiroc's Avatar
it looks pretty easy to set up in a standalone. its a standard 0-5v sensor.
Old Nov 7, 2011 | 01:15 PM
  #449
evosdad's Avatar
that shouldnt be too bad then. i never looked into it.
Old Nov 7, 2011 | 01:29 PM
  #450
JARVEVO8's Avatar
I was reffering to the "new" GTX3576.... But yes! I would like to see a comparison on those two...
I think the GTX3576 TS T3 .82AR would be one bad dude. Something similar to the 7670 EFR!
