Evo Dyno Tuning and Results Discuss vendor and member dyno tuning techniques, results and graphs.
Evo 8 stock turbo/cam Factory Freak
Old Sep 23, 2011, 11:00 PM
marcusE's Avatar
Evo 8 stock turbo/cam Factory Freak 410/401
Mod list :
Hallman MBC
PTE 1000cc
Walboro pump
Full Tbe
Greddy RS Bov
ETS LICP
T bolt clamps
NGK brp8 1 step
E85 30psi dropping off to 27psi
and the key ingredient : TSCOMPUSA aka Tom
E85
93OCT
Tom told me there was room for a bit more but I have some engine noise and rattling to fix that was causing some false knock (Radiator Support bracket)
and the best part? I didnt have a serial cable to log my wideband so Tom had to go off what I told him.. I think his threads speak for themselves.
Thanks Tom!
marcusE is offline
Old Sep 24, 2011, 09:09 AM
marcusE's Avatar
Thanks to tom I stayed neck and neck with a 600 r6 today
marcusE is offline
Old Sep 24, 2011, 01:58 PM
that is pretty unbelievable for stock cams. evo 8 turbo with the small hot side and FMIC, stock intake, o2 housing, goes to show each car is different, enjoy your car!
zeus1 is offline
Old Sep 24, 2011, 02:08 PM
drb
Those are some great results for a stock 8 Turbo, cams, etc. Tom definately knows what he is doing.
Dan (drb)
drb is offline
Old Sep 24, 2011, 03:17 PM
marcusE's Avatar
Agreed. Forgot to mention.. Airbox is gone. Has a spectre air filter that came with the car on it right now.
Also its not the stock 02 housing.. FULL turboback
marcusE is offline
Old Sep 24, 2011, 04:06 PM
ok thanks for clarifying even then your major power adders are still not there which is unreal, saw you were doing the cams maybe (if you can afford) do a fmic at the same time but i think its cool you are wringing out every bit of the stock turbo small hotside 8 turbo
zeus1 is offline
Old Sep 24, 2011, 04:25 PM
well im tuning it on 93oct in about an hr so i will post that result. i would imagine it makes 350 on 93 if it made this on e85. we will find out in a bit. hopefully he extracted the broken bolt in his radiator bracket and its not being held by zipties anymore
also Zack, i highly doubt its a smaller housing on the turbo.. it has to be the bigger 10.5 id imagine that came on some 8 turbos. the cars a 2005.. i dont know what year they started doing the bigger housings on the 8 turbo though. do you?
tscompusa is offline
Old Sep 24, 2011, 05:13 PM
cool look forward to the 93 results. only reason i assumed it was the 9.8 side is because his car is listed as an 03 in his sig but if it is an 05 then yup 10.5
zeus1 is offline
Old Sep 24, 2011, 05:42 PM
sorry you're right its an 03. i would be very surprised if it is a 9.5 housing though.
Old Sep 24, 2011, 05:46 PM
he must have upgraded to a 10.5 or if he bought it used then the previous owner did the upgrade because 03's definately came with 9.8 hotside. (someone correct me if i am wrong though). good luck with the tune it is cool to see all these stock turbos making big power for sure
zeus1 is offline
Old Sep 24, 2011, 05:54 PM
speaking of cool.. its getting cooler outside also.. and with cool air comes higher hp
is there a way to tell if its 9.8 or 10.5 with it still installed on the car? i would guess not ?
Im waiting for him to msg me so i can finish his tune on 93 octane.. he went to olive garden............ maybe he got stuck in the salad bowl
Old Sep 24, 2011, 06:47 PM
marcusE's Avatar
^ was wondering that too Tom, I think I could tell by looking at the numbers on the inlet side. If I removed the maf / intake
marcusE is offline
Old Sep 24, 2011, 07:30 PM
olive garden fwtw.. not that i am aware of on the turbo. yeah cooler temps help for sure usually yielded me more hp and a significant amount of torque
zeus1 is offline
Old Sep 24, 2011, 07:59 PM
03EVOGUY's Avatar
yes there is...if u look on the cold side there should be a factory stamp (where fp puts there stamp) that says "TD05-16G-10.5T or 16G-9.8T"
03EVOGUY is offline
Old Sep 24, 2011, 08:04 PM
steelfire19's Avatar
This is exactly why i am having Tom tune mine in the spring, he always has great results.
steelfire19 is offline
Quick Reply: Evo 8 stock turbo/cam Factory Freak
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
