map ef4 stock block and e85 tscompusa tuned
530-540 is where its normally out of fuel on e85 with a single walbro + enough injector to compensate.. Brians car is running near 13 AFR's though, so the IDC is not entirely maxed out. we definitely need to get a double pumper in it though .. im pretty sure the pumps punched.
next mod = br double pumper or walbro 400.. personally id take the br double pumper anyday over any other fuel pump. been working like a clock on my car ever since i installed it.
Or I had the oldest most tired Walbro ever. Either way great power on stock block.
Your incorrect sir, the ef4 is much bigger then the black. The wheels are noticely different. And even with someone who knows how to spool a turbo fast, I am still full boost by 4800ish for spool. Idk what the black is lbs/min is but I do know the ef4 is in the 60lb/min range.
When I can go back to work and get some more cash, I will be updateing the fuel and I am sure I will be in the 650 range no problem. Hopefully the motor holds up. But if not time for that 2.4 I wanted.
This is surprising to me. We just ran out of fuel on Precision 1200CC on E85 with a single rewired Walbro at 27lbs on a 71HTA. Could not keep it richer than 12.8:1. Switched to a rewired DW300 and problem solved however once we stared pushing it again we ran out of injector. Now moving to 1450's. Seems like a lot of HP on one Wally. Must be a freak pump.
also it sounds odd you're running out of fuel so easily with that 71hta.. your tuner might not have your injectors scaled right and it could be minimizing their max capabilities.
off the top of my head i think you should be able to get around 500 out of 1200's on stock fuel pressure if the pumps there.
i detuned this car awhile ago.. hes been running on 93 or e85 and low boost for awhile now.. theres no point in going for power when the fuel isn't there to support it. in due time he will get some high power though..it will be well worth the wait once its all done.
ah, I see. I've been trying to find out more info on those two turbos, but there just isn't a lot out there. My stroker setup is all MAP, and I was going to go with a FP black, but honestly, I love dealing with MAP, so I may opt for the EF4 instead. We'll see. They've been very good to me.
