680whp~ Evo 8 Stock Block Stock ECU SD 6266@39psi E85 | 146mph traps
Wow. Holy **** thats a lot of power through the stock block. Is this the record for power on the stock block? How long has it been running like this? I'm just amazed its holding up under that much torque. 4g63 ftw.
+1 on mustang numbers. power to you on that thing holding together like that, id be too afraid it would be a time bomb. awesome VD numbers though and good luck on that 9 sec pass.
Also fwiw if it is the bullseye hotside I have found that once you reach about 590whp the hot side really starts to restrict the power above 7k. I have used 2 s362ett turbos on personal cars with the bullseye housing and over 7k and 600hp+ the curve will really take a dive after 7k. Boost really doesn't pick the power up.
Thanks everyone!
I'm not really sure about power, but probably not since STM trapped 150MPH on their stock block
Power on mustang dyno was 519HP, I can't remember what torque. The Mustang I was on reads about 20% lower then a dynojet, also much lower then Buschur's. Last year I made 542 on buchurs, then after a few new mods and Tom adjusting the tune, I went on the dyno I was on and made 498 (same power I trapped 138 with).
Thanks man! Last year I was on the stock suspension as well. Hopefully I can cut some 1.4X 60's on the new suspension. Also with the new found power, and the car being 100lbs (160 with seats removed) lighter in spring, I think we have a really good chance
Yes, it is the bullseye power .70a/r exhaust housing. We actually turned the boost up to 40-41 and it wasn't liking it. We figured that was the most likely the issue. Car likes 35-37 much more.
