How to use Virtual Dyno Properly
#77
Basically My car was tuned by a local shop at 363whp, i just got my 1.3u cable in today n ran a log 2500-7500rpm 3rd gear pull (did like 3 runs) and they all came back reading 287ish whp.... Does anyone know why virtual dyno is reading the logs/runs/pulls as if the car was stock....
#78
#79
selected 3rd gear, input the occ weight, and selected my car (2006-2007 evo 9 mr) and tires n rims are stock so i left that at default
i will say i didnt get a graph for my a/f though...i thought it would log that as i had that checked in evoscan..maybe that has something to do with it?
my evoscan settings are
openport 1.3x, mitsubishi MUTIII and EFI ecu selected
#85
and um id say stock if i had to guess, im not sure as i havent messed with or done anything to my o2 sensor,
mods are
upper intercooler piping, upgraded injectors, fuel rail, full exhaust, intake, and i think thats it, tuned on 93 gas at 26psi, when they ran it it did 363whp
#86
You'd have to install a wideband O2 sensor and gauge to be able to log afr. I don't think your VD numbers are too far off, but maybe a bit low, from where they should be with your mods. Someone with more experience than me should be able to say. I'm surprised it's getting the peak hp that high in the rpms with stock turbo and cams.
#88
spec ops (a local shop in fayetteville, nc) ran a virtual dyno after they had fixed some issues and tuned.
mods are
mods are
#89
what should i set it 2? and i think i have the sensor because i have a a/f ratio gauge and a boost gauge (aem i believe) mounted on my steering wheel) i guess those count as mods i just forget to mention them
#90
Seems like most guys post numbers set to the "VD" setting as opposed to the mustang dyno setting, which reads lower on the actual dyno, and Dynojet, which reads higher on the actual dyno. For reference, I have similar mods and have about 290tq 300hp VD numbers at about the same psi.
So is evoscan actually logging afr? If so, you'd have to have a wideband O2 sensor installed, and it would be wired into the ecu, or you'd have a serial cable coming from the gauge to plug into your laptop.
