TSComptuned - technical data inside / Stock block FP Red HKS 272 e85
#61
**update on original post**
So ive been working on getting my fuel issue straightened out for about a month now. Tom has been very patient with me like always. So I decided to replace my old modded walbro 255 with a new walbro 255. I modded it and put it back in the car and did a pull. ROM was untouched. I went from 12.5 AFR at 7500rpm wot to 11.0 AFR at 7500rpm. Looks like all me and tom need to do now is lean out the map and I'll be all set. I will post final results as soon as we are done!!!
#63
definitely interesting. but if he switched to a new fuel filter also i think that has a lot to do with it as well.
he just passed 480whp and the afr didnt creep higher then 11.6. however the fuel map is pegged rich at high RPM.
I told him this is not a safe way of doing things and should be only temporary. going to share the final graph shortly.
at 29-30psi uptop we are over 480WHP. i just sent him off again with alittle more boost uptop, waiting for him to send the new log.
#65
well he did not get his 500WHP goal, and he really wanted that number. I tried to really push the boost up top hardcore and the car started to detonate, so that tells me we are out of turbo for his mods & of course fuel.
Keep in mind, this cars on HKS 272 oldschool cams, aka very mild conservative cams that should be discontinued based on the other cams out on the market right now.
Here is the final graph for now that will be staying on the car. with a simple cam swap & a double pumper it will put the car around 520WHP solid without changing boost.
dip at 6200RPM ish is where the maps richened, but then you see it goes leaner. Its going leaner on its own. the map is FULL RICH almost in the top end past 7K+.
This car needs a double pumper on it.
#66
As tom stated above, I did not make my 500hp goal. However, that doesn't mean that the car isn't a blast to drive. It feels awesome throughout the gears and as tom stated, with a simple cam swap and double pumper I'll definitely break 500+ safely.
I was telling tom tonight while we were tuning about how much I've learned from him over the years. Being able to actually talk to someone about your tune in explicit detail is something you just can't put a price on. Sure, taking it to a shop and letting someone sit in the drivers seat of your car and tune it is easier, but I guarantee you they don't know their ROMs and maps like Tom's customers do. I feel that with the knowledge tom has given me, I have been able to be way more self-sufficient with my car.
Thanks again Tom, and I'll be hitting you back up when I get some s3's and a double pumper!
-Zach
-Zach
#67
the cute thing about our testing is that knowing the limit of the 255 provides a rough means of assessing dyno numbers. for the most part, i no longer believe any dyno numbers over 500 whp that were obtained for an evo running e85 with a single walbro 255 as the only fuel system mod.
#68
i think we had almost this same exchange earlier in this thread, but having to go full rich on the fuel map shows that fuel demands are well beyond what the 255 can supply and that fuel pressure is in the gutter.
He did have a 416lph walbro installed but something was severely wrong, or he did not install it properly because it was leaner than the single modded was. I dont know if he discussed that with you in pm or not. he definitely didnt make it seal right im guessing and was leaking all the fuel pressure into the gas tank.
#72
1200/1000 = 1.2, and 627/500 = 1.25, so I'd say 500 whp on 1000s is right in line with 627 on 1200s. It will depend on several factors, including ethanol content. E85 in the Portland area is consistently 82% ethanol, so I have a hard time supplying enough fuel for 500 whp on 1100s even with proper fuel pressure.
#73
tscompusa
Oct 6, 2016 10:55 PM
tscompusa
May 23, 2014 01:36 PM
tscompusa
Aug 6, 2013 12:38 AM
tscompusa
Nov 10, 2012 02:44 PM
