Evo 9 - Big power on 93oct from an ETS Twinscroll 6266 turbokit
#31
I know when my twinscroll 6266 with dual wastegates was plumbed wrong (the air lines to my 3 port) I was running really high boost.
Sounds like you could have that hooked up wrong. MAP fixed it for me though so I am not sure what changes were made or how exactly its hooked up now.
To my knowledge is would generate 30psi but that obviously is not the case.
#33
The MV-S gates have three lower ports. You need to connect one of them and plug the other two. The top ports need to be left unplugged for a basic 3-port EBC setup.
If the other 2 lower ports aren't plugged, that is your problem. 38 psi is about where 15psi wastegates top out on boost when you disconnect the lines...
#34
Thanks, I misunderstood that.
Thanks for the info, they are NOT plugged. I'll do that and give it a shot.
#38
Yup, Michael is the man. I'll be doing this tonight and will post up results. Thanks man!
#42
Haha
#45
B) The 620whp was made @29psi
Good pump gas numbers on this turbo regardless!
