Evo 9 - Big power on 93oct from an ETS Twinscroll 6266 turbokit
We finished Phillips evo for now on 93oct. He has to heavy of springs in the wastegates, so we were unable to control the boost. This is 100% on wastegate pressure only. cool thing is, the gas he uses is really good 93oct, so we were able to still get it done even with 38-40psi boost creeps.
This car made real high #'s on 93. higher than most setups do.
*** this is just a temporary result due to not being able to go lower boost ***
I just wanted to share with others how well the 6266 worked even on limited octane gas when pushed to the absolute edge. again though, i didn't do this boost curve by choice! the Tial MVS 38mm gates wont allow any lower boost with the 15psi springs! so if you guys are doing dual gates do not get them each with 15psi springs or this will be your boost curve!
Fuel: 93octane~
ECU: Stock ecu + speed density
Mods:
Built 2.0 Manley pistons / Manley H-Beam Rods
Kelford 272 Cams
BR Double pumper
FIC 1450cc Injectors
Grimmspeed 3port
Greddy Evo2 exhaust
BR 65mm throttle body
Ported intake manifold
ETS Speed density 4" intake
ETS 4" Intercooler
ETS UICP LICP
ETS turbo kit 6266 Ball bearing 1.00 Twin Scroll T4
Dual 38mm TiAL MVS Wastegates (15psi springs each)
Tial Q BOV
ACT XTSS Clutch With ACT Flywheel
heres what it made on a dyno dynamics; (one of two pulls. other one made 595)
Phillip emailed me the following:
Welp the Dyno backed up the numbers and everyone was blown away. I won the 4 cylinder FI class! And folks flip that I had a dyno sheet already with those same numbers lol.
(THIS DYNO IS CALIBRATED TO READ LIKE A LOCAL DYNOJET NEAR THEM)
curious to see what it makes once i can drop the boost around 33psi. def cant be running 40psi on 93 for to much longer.
Fuel: 93octane~
Mods:
Kelford 272 Cams
BR Double pumper
Grimmspeed 3port
Greddy Evo2 exhaust
ETS 4" Intercooler
ETS UICP LICP
Tial Q BOV
Nice work tom
Couple of questions for you friend.
What do you think on same setup but with 6466 t4 twinscroll 1.0 a/r?
Voices say that spool very similar to 6266 but make way more power with a more brutal powerband.
Do you think it will be interesting?
The car in this current condition is only gonna see 1 tank of fuel most likely. its just temporary
This boost will be dropped back to around 34psi or so not sure how much were gonna try and do, but the 38-40psi right now is not going to stay!
Ya its just temporary though until we swap out to the 5psi springs then i will be able to set it much lower.
looks like you have a nice setup yourself.
I am not sure. i don't think a 6466 could make more on 93 though in this cars current situation / case. however a 6466 on a t4 housing? it would kick ***! If you're interested in anything pm me i sold the guy this kit. I try to sell a lot of ETS parts because they are top notch & back up their work with a great warranty if anything ever were to crack or happen.
What do you suggest me?
the 5858 is a nice little turbo. i dont know what your power goals are/were but that turbos not bad.
the goal is 500. The reason i did not go with the 62xx turbo was bcuz this ca ris my DD and i was worried about loss of response. But the ts 6266 u tuned there looks brilliant.
