one of a kind evo 8 stock block custom FF 6266 S3 E85 & 93 | 600whp+ | 10.8 @ 134.95
Update: This car has gone a best of 10.54 @ 136.97 recently.
If you read this post thoroughly, you will see why I've titled the topic the way I did. This car has one of a kind custom unique fabrication parts on it,
and what is the cool part about all of that is, the owner himself is the fabricator.
Scotts car was his inspiration in keeping the engine stock.
Mods on car are as follows:
Stock long block with 80K~ very easy miles
Arp standard head studs
GSC S3 cams
Supertech duals with ti retainers
Custom FF tubular manifold
3" downpipe catless
Buschur bullet 3" exhaust
PTE 6266 journal bearing
Tial 44mm mvr 22psi springs open dump
2.5" hot side charge pipe
3" cold side charge pipe
Tial Q BOV
Custom Garrett 4-1/2x12x24 intercooler
Custom catch can with -10 valve cover vents and -6 block vents
Koyo 1/2 size radiator
Buschur double pumper - 3/8 feed line -6 lines from hard line through rail and regulator
FIC fuel rail
FIC 2150cc injectors
Fuelab mini regulator
Ported stock intake manifold w/ Phenolic intake manifold spacer
Omnipower 4bar map sensor
Competition stage 4+ clutch
Act street light flywheel
Hallman pro mbc
Tephra v7 Speed density
E85 & 93oct - only one pull of the E85 for now taken today in 68F. Smoothing 6 on the e85 pass: 616/439 (Car went 10.8 @ 134.95)
Engine bay:
Link to his build thread: https://www.evolutionm.net/forums/al...by-6266-a.html
Heres a video i took of this car at the shootout that i didnt realize i had!
GSC S3 cams
3" downpipe catless
Tial Q BOV
FIC fuel rail
Hallman pro mbc
Engine bay:
definitely! i want to see the exterior of this car. it has fresh paint on it.
