Ronnie's evo 9 SSL 2.0L 6466 S3 cams E85 | 9.86 @ 145.77
Old Jul 18, 2014, 09:14 AM
  #31
silver9mr's Avatar
Originally Posted by Showbizz41
Ronnie, your car back up and running again? I heard about the issues, without knowing any details... Gonna make it out to Ohio again?
Hes been getting parts together to get it running again from what i have seen
Old Jul 18, 2014, 01:18 PM
  #32
tscompusa's Avatar
Ya it will go 9's this year if it gets done in time. And Ronnie's car is very very heavy. Its a full weight SSL + in dash dvd and navigation etc. So for him to be going that fast is extremely impressive for those who know him personally.
The rod side clearance was to tight on his last engine not allowing oil to properly exit, so the engine didn't last to long maybe a couple thousand miles. His new machine shop is more knowledgeable, and is not skipping any major steps this time.
Old Jul 18, 2014, 06:34 PM
  #33
Ronnie Size's Avatar
Originally Posted by RussellDaniel
Very nice!!
Lots of changes since last season. Mostly to avoid blowing up though.
Curt Brown ported head (with some custom oiling tricks) Block is at the machine shop with new Wiseco pistons, Manley rods, etc. Also picked up an AMS oil pan, English Racing oil pump gear, Frontline Fab CAS covers, hot parts ceramic coated, brembos, valve cover and TiAL covers are out @ Detective Coating now. Oh also removed ACD and the tcase is out getting ACD taken out and new ring & pinion. Over $6k this month alone, fml.
Head:
Block:
Cas covers, custom "chem film" coated at my work:
Gold hot parts:
AMS/Moroso oil pan:
The stuff to go 9s:
Old Jul 19, 2014, 01:15 PM
  #34
tscompusa's Avatar
Looks good Ronnie. That pan will help you a lot. Might be a pain in the *** to seal though.
Old Jul 19, 2014, 02:29 PM
  #35
89jdm240sx's Avatar
Nice build and nice car... Kudos
Old Jul 21, 2014, 07:04 AM
  #36
Showbizz41's Avatar
Will it be in Ohio is the real question?
Old Jul 21, 2014, 07:59 AM
  #37
420a-t's Avatar
Looks awesome man. Take a look at this link for the install on the ams pan. I just installed mine, and had to notch the baffle the same way in order for it to not have a 1/4"-1/2" gap between the block.
https://www.evolutionm.net/forums/sh...632&styleid=28
Old Jul 22, 2014, 10:37 AM
  #38
5LEEPERISAH23I's Avatar
6k in one month is def a lot on any car! I did that in March I think I was closer to 9k tho. All worth it in the end when you get it up and running!
Showbizz41 to answer your question i was talking to him a couple weeks ago, he plans on getting it running before and i think he said his break in is driving it to OH!
Old Jul 22, 2014, 02:04 PM
  #39
d-bo's Avatar
My AMS pan leaked at the oil drain as soon as it was filled with oil. It's an extremely stupid design
Old Jul 22, 2014, 06:07 PM
  #40
I see you also have an AMS pan that doesn't have their logo welded on. I'll probably trim the baffle tomorrow at work, and I'll be checking the flange straightness as well (on a granite surface with an actual dial indicator on a height gauge)
Old Jul 22, 2014, 11:12 PM
  #41
khmerpimpin's Avatar
what tires were you running on the old 10.1 pass
Old Aug 8, 2014, 08:52 AM
  #42
4g63evoeight's Avatar
M&H 245/45/17 drag radials
Old Aug 10, 2014, 04:24 AM
  #43
evoix973's Avatar
nice set-up
Old Aug 10, 2014, 09:45 AM
  #44
SiriusEvo's Avatar
Thats a lot of boost for 750whp on that turbo, seems like it should be higher
Old Aug 10, 2014, 03:22 PM
  #45
d-bo's Avatar
I think he said timing wasn't really agressive. Looks like 40~ psi ? Takes upper 40s on a 2.0 to hit 800 on a MD. doesn't seem that off
Quick Reply: Ronnie's evo 9 SSL 2.0L 6466 S3 cams E85 | 9.86 @ 145.77
