Switched to E85 and only Made an Extra 16WHP
#31
Guest
Ya i was going to say the gasket is probably blown also depending on how long the leak was there.
Well now you know what the issue is! once you get a new gasket and retap / fix your leak you should spool 10x quicker and it will make more power. be careful though, it may boost way higher then it is now after you fix that leak.
#34
Guest
#36
I understand your theory here but I've had plenty of trucks at work that will have almost no power due to blown manifold/turbo gaskets so I wouldn't doubt that this is all of his problem. You have to take in account the size of the leak, maybe a small leak would be a slightly bigger a/r but a large leak like he has could effectively be making it a huge a/r which would put the turbo way out of it's efficiency range.
#40
I agree with this.
Only in the event that the exhaust leak is large enough for the turbo to not reach the target psi will you loose peak power. Still does not explain what's going on here.
#41
The exhaust leak explains the lag. The lack of power though....is your cam timing set properly? That could be part of the problem. You don't need cam gears at your power level. You also should be well over 26-27 psi if you are trying to make optimum power. Most cars locally that are on IX sized turbos are running 31-32psi peak to make good power. Not 27.
#42
Guest
#45
Guest
