Built 2.0L ETS t4 twinscroll 6266 S2 cams Skunk2 94oct
#34
You were running out of fuel on a wally 400 at under 600whp? Sounds like something else in his fuel system is holding him back, shouldn't run out that low to require a double pumper yet. The wally 450 on my car put down 775whp on e85 no less.
But regardless, glad you have it all tuned up, looks like a very potent pump gas car.
#35
#36
I did a lot more than just slap it in there, so its not apples to apples.
I had the Wally 450 (e85 version for reference), I ran a new AN fuel feed line (-6AN, not too much bigger than stock), Adjustable fuel pressure regulator, boomba fuel rail, fuel lab fuel filter (the big *** one), fic 2150's and modified the return in the pump housing.
So yea, its a "bit" different. But i am on e85, so the extra pump room i have there should be neglected since hes on pump gas. I guess I am just saying he probably had other fuel constraints besides his pump that were holding the setup back and he was simply able to overcome those by getting A LOT of fuel pump in there.
#37
He may be approaching the limit of the factory filter. Like I said I was going to use the stock hanger but thought I would run out of flow no matter what pumps capacity was before the filter.
#38
I know some cars work good with the 450 and some not. The main key is to get a boost a pump or use a really good wire from battery to pump so it runs a lot of voltage. the pump will flow like crazy with lots of voltage. Then upgrade the feed line, and get an adjustable FPR, and it really flows. Most guys that run this pump don't have everything setup right and instead of making them jump through hoops, i just recommend the double pumper since its more convenient and guaranteed to work great with the car. But when a 450 setup is done right, they can flow quite a bit of fuel.
#39
tscompusa
Apr 10, 2015 04:47 PM
tscompusa
Oct 20, 2014 02:31 PM
tscompusa
Aug 28, 2014 01:02 PM
tscompusa
Mar 4, 2014 12:57 PM
