Evo Dyno Tuning and Results Discuss vendor and member dyno tuning techniques, results and graphs.
Stock block FF S366 budget build 93oct 28-29psi
Old Oct 30, 2013, 03:09 PM
Liked 61 Times in 53 Posts
Posting this up for Basit. Basit recently bought a new evo bone stock with 115k miles on it. Everything was pretty much stock in the car. He started swapping parts, and ended up with a bunch of different brands on the car.
After driving it for a bit he added the following:
PTE 1200cc
kelford 272
eBay / S-Max 4" FMIC
Tial WG & BOV
Aluminum driveshaft
Forward Facing Borg Warner T3 s366
3" TBE
Tephra v7 SD
At 26psi it made 493whp
At 28-29psi it made 523whp / 10* uptop
Im impressed by this car. The fact its on 93 octane and how it made power with off brand parts on it.
Graph: (Temps outside 55-60F) (Max smoothing: 519/373)
Few pics of car before & after modded;
I would like to thank Steve / 5LEEPER for helping Basit with the logging and setting everything up. that makes it 10x easier for me. If anyone is from the Philly area that is scared to do this kind of tuning and needs help Steve can help no problem. It makes the tune session go much much quicker when a veteran is in control of the laptop / evoscan / logging.
tscompusa is offline
Old Oct 30, 2013, 03:23 PM
5LEEPERISAH23I's Avatar
Liked 1 Time in 1 Post
This car deff rips! Compared to my 2.4L FP Black it feels super lazy spooling. We are comparing a 2.4L smaller turbo on E85 vs Stock 2.0L on 93 pump so thats expected it just makes you appreciate the 2.4L bec you forget how laggy the 2.0 is.
It is for sure making every bit of 520whp feels super fast once it gets going. I think this car with good driving should go 129-130 in the 1/4 miles easy!
5LEEPERISAH23I is offline
Old Oct 30, 2013, 04:40 PM
emotart's Avatar
Liked 0 Times in 0 Posts
Nice to see another stock block car rocking 500+whp! Although that thing seems like a lag monster, I guess it only helps keep his motor together haha. I would love to see what the set up does at the track.
On a side note, where did you get the plexiglass shield for the bumper?
emotart is offline
Old Oct 30, 2013, 09:58 PM
With his tq it should last awhile! I think the motor has 114k on it so it will be interesting to see how long it holds up.
The plexiglass he made it i believe from home depot.
Old Oct 31, 2013, 02:26 AM
damn this turbo is very good!
do you have a boost log just for reference?
thanks!.
seems to be not to laggy.
It is a very big turbo!
66mm inducer & 91mm exducer rated at 82lb/min.
el.guerrero is offline
Old Nov 1, 2013, 04:03 PM
mitsubeastlee's Avatar
Liked 2 Times in 2 Posts
thanks!.
82lb min is exactly what the 6466 is rated to. This turbo does spool up very nice for its size just like the 6466!
mitsubeastlee is offline
Old Nov 3, 2013, 11:41 AM
yes...
https://www.evolutionm.net/forums/ev...ali-91oct.html
this is a good comparison with 6466.
Also they have the same cams.
this bw s366 is very cheap and good!
waiting for tom to know if it has a boost plot.
Old Nov 3, 2013, 04:01 PM
d-bo's Avatar
awesome ! i was looking to switch this turbo and FF setup as an "upgrade" from my 35r. i think this turbo really needs more boost to wake the car up and can be fully taken advantage of on a built motor with a 2.2/2.4. it would probably just be a lateral movement for me.
happy to see this on here and how well it did. i will probably run double batmowheel's though
interested in a boost plot as well
thanks for sharing
d-bo is offline
Old Nov 3, 2013, 04:32 PM
Evoloved's Avatar
TSCOMP
Could you please overlay this with the 2.0 6466 on pump you recently did.
Evoloved is offline
Old Nov 3, 2013, 09:56 PM
yes...
i didnt log boost, and yea he bought it off ebay used off a honda guy for 400 shipped or somthing
Old Nov 4, 2013, 12:46 AM
Levar's Avatar
Liked 4 Times in 4 Posts
So..., the S366 is comparable to the 6466, right?
Levar is offline
Old Nov 4, 2013, 06:53 AM
tom please overlay it with the 6466..
thanks
Old Nov 4, 2013, 07:32 AM
I think the S366 is a little bigger then a 3586 or like a 6266
Old Nov 4, 2013, 10:00 AM
is a 66mm compressor.
Old Nov 7, 2013, 03:29 PM
Thank you tom car rips but I wish I had a 2.4 . Still re learning how to shift car has act clutch so I'm trying to manage 4th gear lockout. Hopefully hitting track this weekend. Posting up more pics soon.
basithi is offline
Quick Reply: Stock block FF S366 budget build 93oct 28-29psi
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
