My dyno results stock turbo e85 388/472
First of all, I am new to posting on this forum, so I apologize ahead of time for my noobie actions if I make any haha
My mods
Full 3" exhaust
Vibrant intake
Full short route intercooler piping
Nisei intercooler
Jacks built transfer case
AEM fuel rail
RC 1250cc Injectors
Fuelab fuel pressure regulator
ARP head studs
Cams
Halman boost controller
ACT Xtreme Duty Clutch
All work done by me.
31.2 psi e85 stock turbo tuned at 5,000 feet above sea level on a MUSTANG DYNO.
When I bought the car almost 4 years ago, I was under the impression that it was all stock and untouched. But the plate on the front of my block is shaved, and the VIN on my transmission traced to an evo 9 transmission. I have pulled off my oil pan and from what I could see, the rods looked stock. Are these normal numbers for a 2.0? Tq seems kinda high right? Would be nice to have some EXPERIENCED tuners chime in.
388/472
My mods
Full 3" exhaust
Vibrant intake
Nisei intercooler
AEM fuel rail
RC 1250cc Injectors
ARP head studs
Cams
388/472
I'm hoping for your rods sake that your tq numbers are off lol that is a very dangerous amount off tq for stock block to handle. But IMHO those numbers have to be inflated that's over 500tq on a dyno jet and for your mods it's wrong unless like stated you have a stroker motor then it could be more likely
I really hope not! haha but I am pretty positive they are stock rods. I have put about 10k miles on my car since the tune and haven't had any troubles yet! ... I better go knock on wood.
I'm sure he's a good tuner man but I just don't see a stock turbo on a 2.0 making that much tq even on e85 unless there is more to your car then you know. In which case you should be very happy I would just double check things cause that much tq that soon if they are stock rods and it really is making that much tq that block will have a skylight sooner then later my friend. Good luck and hope it works out in your favor
Im assuming this is on Tobz dyno? And if you were on the dyno recently with these single degree temps im gonna say his correction factor is a little high. but i agree with others about the ticking time bomb. Most stock block cars will make 410lbft+ and because torque comes on so hard and early your rods are gonna hate life soon enough
Yeah, me neither, that is why I posted this haha if something is done to the turbo, it fooled me because it is still in the stock housing, it has absolutely no shaft play at all as well. i just have a hard time seeing this as a 2.0 as well. All I can do is pray for my block to hold up for now! haha
Yup Tobz dyno. But this tune was done several months ago in about 85+ degree weather. So far it has held up, but I agree. I need to tear it down to make sure. Because most guys I have seen keep the stock block at about 380tq and I have still seen rods get bent because of it.
Cool, thanks. I feel stupid for even asking you how to do that haha that was pretty self explanatory. I'll measure this soon if the weather warms up. What are the chances that the block is stroked with stock rods? Maybe a 4g64 with oem evo rods? I have pics from when the oil pan was off, I will post them when I get off of work later and maybe that will clear some confusion.
Thank you all for the replies!!
What exactly are you trying to imply? The closest thing I have seen to this was some guy on youtube made 400whp and 522tq on a 2.3 stroker with stock turbo. The dyno is accurate guys, this dyno sees multiple Evos every single day of the week.
I'll end the confusion today by measuring stroke. It finally warmed up and isn't -20 degrees outside so I'll measure and post it later on today or tomorrow.
Here are some Mustang Dyno results from a few years back from the 2.4 L stroker I had tuned on E-85.
https://www.evolutionm.net/forums/ev...-2-4l-e85.html
The turbo was an original style FP green. Not really much bigger then a stock turbo. Prior to this I was tuned on E-85 with the 2.0 L that made approx 390 wtq. I ran it that way for almost 2 years till the stock rod vented the block.....hence the stroker build. Wouldn't be surprised a bit if you are displacing more then 2 liters.
Good luck with that torque.
