EnglishRacing SLR2.2 PTE 7175 1084/744
#33
Aaron,
Whats your take on re-stacking the rear diff? something everyone should get done or only if car is used for drag racing? noticed you guys mentioned doing it to this particular car. I have heard of slight noises when turning after doing this mod, whats your take on cons vs pros ?
thanks!
thanks!
There was a 1-2-1 because of how easy the dogbox shifts. It hit 12,000 before the clutch disengaged. It still runs and drives but we have enough experience to know that the valves are now suspect as well as springs.
Comp Triple
#40
Nice numbers. I like the idea of a 2.2 slr. Ever do this setup in a 1g, I'm wondering if it's possible to fit aluminum rods in a 6bolt 63 block with 94 mm stroke?
#42
Great build Aaron.
Curious, I just did a few quick sums on the fuel system and flow requirements, running 40+ base pressure with that boost on a turbo that size on E98 pushes it way past normal 044 ability.
Assuming you're running alot higher pump voltage?
