Evo IX stock block FP Red GSC S2 E85 34.7psi | 570WHP
Old Apr 4, 2014, 10:21 PM
tscompusa's Avatar
Originally Posted by Evo11V
Some awesome numbers! I'm going to see how to squeeze out some more power out of my setup one of these days. BTW I've been running 35PSI for about 5 years on the FP Red.
Spiking to 35psi low RPM and running it at high RPM are completely two different things. That's why you're making tq and less power up top, because your boost is falling off.
shaft speeds at 35psi at low RPM are nothing compared to high RPM and 35psi.
Originally Posted by slow gst
Wow. That is a pretty sweet setup 500+whp on stock block.
I do one over 500 just about every week.
Originally Posted by boost556
very nice, but should be concerned about that much Tq on the stock block??
It is fine. But so we can push it even harder, I'm gonna build him a short block so we can go all out and make a ton more torque and mid range power.
Thanks guys.
Old May 23, 2014, 01:56 PM
eckok24's Avatar
Man I'm running the fp red ill b happy with 450awhp
Old May 23, 2014, 02:02 PM
ctfpevoVIII's Avatar
you will be able to hit that on pump 93 oct with a good tune.
Old Jun 1, 2014, 05:45 PM
Nohatn's Avatar
BRAVE... great numbers!!! but BRAVE
Old Jun 2, 2014, 08:37 AM
linkin's Avatar
awesome numbers
Old Nov 6, 2014, 01:28 PM
vmrevo9's Avatar
nice setup! I have been eyeing a similar combo. nice to see some results. great job
Old Nov 6, 2014, 05:40 PM
ken9gsr's Avatar
car is still running strong! but i am looking to build the block soon and bigger turbo.
Old Nov 12, 2014, 01:22 AM
tscompusa's Avatar
That is awesome! Glad its holding up. when you're ready to build the block let me know!
My 2.4L would run real good in your car. maybe something to think about. I'll give you money for your 4g63 core.
I'm switching to a 4g63 soon so i can run 45-50psi to redline.
Old Nov 18, 2014, 11:47 AM
arman.hamzic's Avatar
Incredible for the stock block
Old Nov 18, 2014, 12:30 PM
Mark_L's Avatar
How are you getting it to hold that much boost at higher rpm? My red tapers down to around 27ish psi up top. Good numbers.
Old Nov 19, 2014, 02:45 AM
Boost Demon's Avatar
Nice work with the hybrid boost control.
Old Nov 27, 2014, 03:03 AM
tscompusa's Avatar
Ya 3 port with mbc.
The 3 port is set to give it more boost at high RPM where the tq peaks off.
Old Nov 28, 2014, 05:30 PM
PatNy's Avatar
Is this a new style red?
Old Nov 28, 2014, 05:59 PM
nismogtr34's Avatar
No. New style FP turbos have the stainless steel housing also they've eliminated the wastegate actuator.
Old Nov 28, 2014, 11:52 PM
EvoTurboTurk's Avatar
Have you got a intake fitted to the turbo?
Quick Reply: Evo IX stock block FP Red GSC S2 E85 34.7psi | 570WHP
