Evo IX stock block FP Red GSC S2 E85 34.7psi | 570WHP
#35
570WHP should be about a 131-132 trap speed depending on setup.
Its been 9 months since his tune. I have hundreds of stock blocks around this power level without issues for years and years. I usually keep the torque under 400wtq however whenever I can.
It really comes down to how the cars driven, and the past history of abuse if any it has encountered from prior tunes / maintenance or maybe neglect from tuning after modding and so forth.
It needs a built engine to be pushed harder, and his torque level is the max id go. The highest I've had a stock bottom end was 550wtq or so, and at or around 750whp, which never blew up. It ended up bending a rod though at the track after around 500+ passes at the 600-700~ power level.
#37
You would be better off to put a screen, or a small filter directly on the inlet, rather then just run it fully open.
Unless you're referring to something else?
#38
You can run an open turbo inlet yes without a filter, but heat wont be of your concern, the lack of filtration infront of the turbo inlet will be!
#39
" It really comes down to how the car is driven." Tom can you explain? Not trying to be a smart as, just trying to gain knowledge. So is it safe in all driving conditions? And I thought that the general census on stock bottom end boost levels was 30 ish for worry free driving? Also are you still getting results with s3 on stock turbo? About to replace my s1. I remember an older post that you were recommending them to all your customers. Thanks
#41
This cars on a 3 port so it would be very hard to kill it. Its not going to run different boost in 4-5 gear. its tuned to be safe in that regard.
The easiest way to kill a stock block though is to load it up, meaning put it in 4-5 gear and smash on it at low RPM. it will make a lot of tq sooner and load the car up.
What a car makes per boost level is based on the efficiency of the setup. one car at 30psi might only be at 380wtq while another 480wtq. So not a good example.
But as I said, the boost is controlled in this car.
I dont have any logs showing that for this car. What I can say is:
1250cc inj on a 2L can support about 650whp dynojet estimated give or take.
#42
What all has been done to the head other than cams/springs/retainers/head studs?
I am 4k miles away from having to do my 120 maintenance on my IX and at the same time of doing the 120k I want to do what it takes to acheive power like this with similar setup. I'm maxed out in bolt ons, stock Turbo cosworth 272s and e85. Currently making 404 awhp. Thanks for the input!
#43
Boost control is key to making a lot of power. I don't see why you couldn't make similar or the same power as this car
if you use the same mods & similar tune.
#45
FIC 1050cc is going to be cutting it close on a 2.0L. Off the top of my head 1200cc is roughly good for about 620whp dynojet on e85 with dual walbro 255.
So 1050cc is going to be a little small. Id upgrade to give yourself some extra reassurance to keep injector duty cycle within safe limits.
