BBK-3B - my new favorite turbo
#92
I put a boost gauge pre and post throttle and I have seen greater than 10+ psi difference during part throttle conditions. Factor that into surge and target boost calcs. I always liked seeing what happens when you go up a hill and you're in a high gear keeping manifold boost low and pre throttle will be opening the wastegate. For a turbo that hits like this id be sure to tinker with that!
just to illustrate my point as well as others in this thread. sorry for the crappy video but you can see that even at part throttle the pre throttle boost is already hitting wastegate which is 15ish lbs during this Secondary air system test.
#93
To add to the boost control discussion, I ran my first autox event on Sunday with this setup. It was a test and tune, and one element was a 55-60 mph slalom that went on for days. It 8 cones iirc, so plenty of time to develop a steady state rythm with fine throttle control. Doing the above mentioned changes and tuning, I have never had the car feel more controllable in that situation.
To add to the 3b discussion, this was also the first event in the dry with the new motor on the 3b. I ran the 3b on stock motor last year and it was a great autox setup, but there was noticable lag in really slow digs. With the new motor I also had lag out of a few digs, but that was because I was spinning all four Love this turbo!
#95
http://youtu.be/kB9Sr3YI8PQ
but this video open my eyes to something else. BOV flutter at part throttle. with there being such a large diff pre and post throttle its no wonder the BOV cant stay on its seat.
#96
this is very interesting video. i have been running wastegate line from compressor outlet or lower I/C pipe for about ten years now. I did notice years back car felt faster on a manual boost controller with the signal line coming from the intake manifold. there is pressure drop at i/c so signal is not the same pre and post intercooler WOT. at that time I never considered part throttle effects. so there is actually three distinct boost signal locations with varied effects. manifold, upper i/c, and pre i/c.
Yes you have to chose your reference according to what you are trying to accomplish.
I know you like the type s so I'm sure you've nailed your drivability
#100
I had similar experience @ ATCO. the car would hook up nice out of the hole, but as soon as I go to WOT, all 4 spin with a little sidestepping. I couldn't get better than 1.8 60'
#102
These last four weeks its mostly been raining, or I have been out of town, so unfortunately, I still haven't had any good chances to really rip through the gears to get a feel for the transient response. I suppose that means its not light years better than the JB BBK Full or Green. Still, I like it so much that I've already sold the BBK Full and HTA Green.
#103
I went back to a softer spring and it solved most of the flutter. I only get occasional flutter in 3rd/4th around 3k rpm
I cut 1.6 60's last year during Pro Solos on un-prepped surfaces. That was with bbk on stock motor and Hoosier A6s. With my race tires on, I can go wot in 1st with reasonable control in a straight line. The 2nd gear all wheel spins are on corner exit where lateral g's are still present. I admit I was going outside the friction circle on purpose, because all wheel drifts are so damn fun
